I typed a long reply with samples to the following thread
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/271198-can-pentax-lens-do.html
and when I pressed the 'Post' button, I found that the thread was closed due to the OP ending up being beaten up for posing a query that some found challenging.
So here's my reply.
(To OP, I certainly think the sample photo is nice and the query work a discussion)
So since I've typed it already... might as well post it.
Can a mod kindly add it to the closed thread? TIA
Originally posted by Parallax Respectfully, I think the scene, the lighting, the composition, the the look on the face of the very attractive woman, all coming together perfectly at the right time, is what is creating the atmosphere that makes this picture what it is. I don't believe it has anything to do with the lens. In fact, as I alluded to above, a lens with better bokeh qualities would have made an even more striking picture.
I think you hit the nail on the head.
Its all the elements coming in and the really attractive woman, mysterious look too and engaging look into the camera/viewer than tops it off for the shot.
Its the photographer that counted here more than the very expensive lens.
'God Particle' is on my Flick list.
I don't see the reason to slam his shots just because a poster threw down the gauntlet (as to what lens can give the same look) and used his pict as an example.
Its a good shot and I would suggest anyone who put his shot down to post their own 'perfect' samples.
As for the original question.
I would say 'Yes' as to coming up with a shot that is 'like' the example.
I'd say 'like' and not 'same' since it would never be with different focal length, bokeh, working distance, color rendering, drawing style.
Esp. so when its a M9 (FF) with a 35mm, f1.4 lens that is really quite small for f1.4 over apsc (different working distance for the same FOV, not as small lens or maybe totally different FL used, etc)
That shot set a high bar to me, I may have 'like' shots in terms of DOF/seperation, but I won't have a stunning beauty to help take the viewer's breath away....
Some samples (on FF thought)
A50/1.4
FA77ltd
K50/1.2
Super Takumar 135/3.5
