Originally posted by Vranx If I use a rectangular 180 degree fisheye lens on a film body, I know it is 180 degrees angle of view. But on an APS-C body?
Is this calculated similarly as the crop factor for focal lengths? And can this be used for any lens and its angle of view?
What angle do I get from my 180° fisheye, focal length is 16mm, by the way?
Please enlighten me!
Thanks in advance,
Vranx
Just to clarify this for us please. There is no such thing as a rectalinear fisheye. A lens is either rectalinear or fisheye.
Second field of view is related to format so a 180 degree field of view on full frame is not z180 degree field of view on APS-C. The actual field of view will depend on the amount of barrel distortion present. But a 180 degree fisheye on APS-C will likely give a 180 degree field of view circular image in the middle of a full frame Or maybe a little more with vignetting in the shape of the lens hood
We can't predict what you will get unless you tell the exact lens you are using
