05-11-2008, 06:55 AM   #1
Options for 60-250mm while I wait?
I currently have a Tamron 300mm/2.8 that I am not using much due to the size and weight - I have kids now....
I see that Pentax will have a 60-250mm 4.0 soon, which will be perfect.
Tamron 70-200mm/2.8 with a 1.4X would also work - but it is not out either.
I do have the Pentax 50-135mm/2.8 Are there any teleconverters that work with SDM? Or will the lens revert to normal type focus?
Sigma has a 100-300mm/4.0 lens also, but it is expensive.
05-11-2008, 10:42 AM   #2
heatherslightbox's Avatar
What about getting the new DA55-300? I know it's not constant aperture, but it does produce pretty decent pictures for the price and it's lightweight, too. Even when the *60-250 does come out, you could still hang on to the 55-300 for those times where you'd rather not lug around a heavy telephoto.
HTH,
Heather
05-11-2008, 01:43 PM   #3
I bought the Tamron 70-300 LD Di Macro for this very purpose - to use until the DA* 60-250 is available. I love it, especially for $130 shipped.
05-11-2008, 01:45 PM   #4
ankit's Avatar
jsherman, where did you find the tamron for $130 shipped?
Also, do we know the dimensions/weight of the 60-250 yet?
05-11-2008, 02:03 PM   #5
QuoteOriginally posted by ankit Quote
buydig.com
Aside from some CA issues, the Tamron 70-300 is very, very sharp for the price, even at 300mm and even wide open. And the 1-2 macro is exceptional.
The samples I've seen from the DA 50-300 are excellent, though. I just don't want to spend that much on a lens I'll be replacing with the 60-250.
05-11-2008, 03:22 PM   #6
Torphoto's Avatar
They better release the 60-260 soon I'm ready to pull the trigger on a 100-300
05-11-2008, 03:26 PM   #7
cardinal43's Avatar
I'm not jsherman, but I have stayed in a Holiday Inn Express.
I got mine at Amazon for $129. I like it a bunch.
05-11-2008, 04:24 PM   #8
Just curious, does anyone know the price-point of the 60-250mm?
05-11-2008, 04:41 PM   #9
The only thing I can gather on a release date is that it's supposed to be sometime this summer. Size-wise it looks like it's going to be a pretty good sized lens, bigger than the *300:
Price-wise it's hard to say as both the Sigma and Tamron 70-200/2.8s run in the $700-800 or so range. With the *60-250 being weathersealed and a constant f/4, I don't know how that's going to affect price in comparison with the Sigma and Tamron 70-200s.
If Pentax were smart, they'd make sure the *60-250 got released this summer around the same time as the Tamron 70-200/2.8 to give the Tamron and Sigma offerings a little competition. Price-wise, they'd be smart to price it in about the same price range as these 2, as some people wouldn't have a problem giving up a bit of aperture to get weathersealing.
I just wish Pentax would bring weathersealing to some of the less expensive lens offerings, as I think they could really get a leg up against everybody else in the consumer-prosumer DSLR lens market.
Heather
05-11-2008, 04:46 PM   #10
ankit's Avatar
Thanks for that pic, Heather. I think that settles it. I don't need to wait for the 60-250 - its just too big/heavy for me. Now the chioce is between the DA* 50-135, the DA 200mm, and the 55-300...
05-11-2008, 05:03 PM   #11
Torphoto's Avatar
Sigma 100-300!! cause I need a lens now :-(
05-11-2008, 05:30 PM   #12
Thanks Heather, I'd be happy if it is in that price range. My lens savings account is getting to the point where a 60-250 in that range is feasible. I hope you are right. Reports on the 55-300 are tempting, but I'd really like weather seal.
As an aside, I noticed a plastic ring bouncing around inside my Sigma MF 400mm/5.6 APO. Sigma says they can't fix it (no parts). I'm going to take it to a local shop to see if they can do something with it.
05-11-2008, 06:19 PM   #13
Ankit,
Besides price, you are right in considering weight as well. If a lens is too big and heavy for you, then you're not as likely to use it. If you have a pretty large budget, then the 50-135/200 combination would be ideal. If your budget isn't that big, then perhaps a 50-135/TC combo would work.
Have you considered the Sigma 50-150/2.8 EX HSM II? B&H has it for $749.00, so it's in the same general price range as the *50-135, but it gives you a little more range on the tele end.
Overall, though, I think the best bang for your buck is the 55-300. It's definitely a step up from the Tamron/Sigma 70-300s and it's about half the price (or even less) than the *50-135 or 50-150. Mine will be delivered on Tuesday, so I'm anxiously awaiting it's arrival. Once it's in my hands, my Sigma 17-70 won't be lonely anymore.
Even if the *60-250 was affordable to me, I still might not get it because of the weight alone.
Heather
05-12-2008, 01:04 AM   #14
gkopeliadis's Avatar
QuoteOriginally posted by Torphoto Quote
Sigma 100-300 is a remarcable lens (at least on a Nikon mount). But it's "wide" end is to long for many circumstances.
05-12-2008, 09:22 AM   #15
This Sigma 100-300/4 is a very strong competitor. But it is probably a lot heavyer and larger than the DA* 60-250 will be when it materielises. So, if weight and size matters ...
I'm very curious about the performanse of the DA* 60-250. I hope it will be in the same class as the 50-135.
If it ain't, then I might end up using the 50-135 with the new promised TC.
60-250mm, k-mount, lens, pentax, pentax lens, slr lens, tamron
Sigma 70-200mm or wait for Pentax 60-250mm Dieni Pentax SLR Lens Discussion 17 08-11-2010 06:19 AM
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
PENTAX 18-250mm VS QUANTARAY 70-300mm@250mm charliezap Pentax SLR Lens Discussion 7 02-08-2010 11:38 PM
All times are GMT -7. The time now is 03:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
