Why the older green version of 15 ?
I ran across another similar recommendation and I think it had to do with the aperture blades but didn't have opportunity to ask into it...
Originally posted by AquaDome ...recommend the green-stripe (non-HD coating) version for the Limiteds...
---------- Post added 09-03-14 at 03:43 PM ----------
Sorry, you answered my question in your post :^|
I suspected it might have something to do with the stars.
That is an aspect I like...
Originally posted by AquaDome ...HD coating diminishes the twinkle-star lens flares which the non-HD version is famous for.
OP I also recommend checking into pictures taken with the 15...
Using any wider angle lens is really a style rather than just extra width for field of view. I think so, anyway...
As far as just increasing field of view for a pano or something, I prefer to stitch 21mm. For pano look 2:1 or 2.5:1, I would use the 15mm in landscape or 21 in portrait (about the same vertical view, feet to sky)... Some things aren't easy to stitch and I think I am rambling.. Point is, for just more field of view, there are options like stitching.
However, for using the 15 in an artistic way close to subjects and wide backgrounds or whatever... need the wide angle lens. This is the style way...
Maybe you have a specific use for the 15 in mind.
Perhaps think some more if you just want to cover more real estate, though...
