09-04-2014, 11:07 AM   #31
From your post - I can primarily assume that you're not getting much into the 70-300 - which I can relate to.
Personally, you're in a similar boat to myself.
The 18-135mm WR is a great walking lens, with a couple of caveats.
1. Its not the fastest lens
2. Its not sharp in the corners/edges
I'd pick one up for a 'daily use' lens as its light, decently sharp, WR and covers typical use ranges from wide to tele.
For something sharper, I'm considering either
Tamron 17-50mm f/2.8 or a little narrower 28-75 f/2.8. Both have great reviews.
I've tried out an inexpensive Vivitar (manual) 28mm f/2.8, and it was very sharp, and only $20.
Its a decent landscape lens, but might not be wide enough.
09-04-2014, 11:20 AM   #32
Stavri's Avatar
Looks to me like you need and UWA, Pentax 10-17mm is a great lens with amazing IQ. Sigma 10-20mm f4-5.6 is also a nice second choice. The 15mm limited is a great lens, but expensive. If you want a wide prime, I'd recommend a Samyang/Rokinon 14mm f2.8.
09-04-2014, 11:40 AM   #33
Former, that's exactly what I want the 18-135 for. Just every day shooting. The speed isn't that important as it'd primarily be used during the day or in situations where I didn't need anything faster. The 17-50, while couldn't complete replace the need for primes, is fast enough that I could use it in place of wider primes.
And stave I, I will look into those mentioned.
09-04-2014, 12:22 PM   #34
Yeah - primes are pretty much impossible to replace (stack of primes?). Wide / Tele primes get pricey unless you go manual.
Rokinon/Bower/Samyang 14 and 16mm are 'affordable' on the wide end. AF Pentax will pretty much be double. Similar on long end - I actually have a Rokinon 85mm f/1.4 - I just don't get much use of it.
Many older lenses are probably a decent deal here.
09-04-2014, 07:19 PM   #35
ramseybuckeye's Avatar
The 18-135 can do starbursts too, most lenses can
09-05-2014, 05:43 AM   #36
Those stars from the 18-135 are not bad
The arms are pretty crisp
A different character from DA35.
Different Tamron 17-50 as well, if I remember correctly.
aperture blades, da, field, fl, k-mount, lens, lenses, pano, pentax lens, pics, post, size, slr lens, stitch, strengths, style, tamron, version, view
Which direction? Auto or manual Another dyemention Pentax K-30 & K-50 16 05-06-2014 04:32 PM
Questions about upgrading to Legacy Lenses Styx1284 Pentax SLR Lens Discussion 22 02-03-2014 09:37 AM
Upgrading from kit, so many options, which is right for me? 135mm 200mm? SlyClockWerkz Pentax SLR Lens Discussion 15 08-21-2013 04:02 PM
What lenses have same focus turning direction? striker_ Pentax SLR Lens Discussion 7 03-02-2013 02:37 AM
What direction to go with my lenses? What's next? jtkratzer Pentax SLR Lens Discussion 21 11-04-2012 07:19 PM
All times are GMT -7. The time now is 11:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
