Originally posted by DennisH I'm also interested in this lens. What is the max aperture at various focal lengths, particularly between 20 and 35mm?
This may help. This lens (17-70 C) was the key comparison against the DA 18-135 WR in the most recent in-depth review. In it was a variable aperture range chart that you may find of benefit comparing the two lenses (and the DA 18-55). The below was taken from that review:
It's been mentioned that this is a variable aperture zoom lens. In order to make it easier to visually grasp the exact aperture range of this lens, namely where each maximum and minimum aperture lies along the entirety of the focal length range, we've created the following diagram for you. Above the axis lie the maximum apertures, with the minimum possible openings underneath. In addition to the DA 18-135 WR and the DA 18-55, we included the latest incarnation of Sigma's 17-70 as well so you can see how its variable aperture range compares. We were quite astonished to realize that with the 18-135, you lose only 1/3 of a stop for the majority of the zoom range, with the greatest variance being 2/3 stop between 28mm and 45mm. Compared to the much heavier and larger-front-element-wielding 17-70, we expected a larger difference between the two, especially considering how that with the 18-135 WR, you get not only weather sealing, but an additional 65mm of optical zoom.
Regarding the zooming of the lens, the 17-70 C is opposite that of Pentax lenses (which start with the lower focal length on the right side when looking at them top-down). This .gif (also from that review) should make that clear:
Hopefully this helps, and if you wish to view that review, that's substantial comparisons between these two lenses, especially with sharpness and bokeh. To visit that in-depth review,
click here.
-Heie
