09-06-2014, 07:12 AM   #1
jcdoss's Avatar
Problem with M28/2
I recently picked up one of these, and took it out last night to shoot around town after dark. Turns out, mine is quite susceptible to flare or ghosting from bright light sources in the frame. I don't find much in the reviews that this is a problem, but it's also a rare lens. Is it a problem inherent to this lens, or is it fixable?
I'll post an example later, but I think this is the worst I've seen.
09-07-2014, 09:19 AM   #2
QuoteOriginally posted by jcdoss Quote
Was there a filter on the lens?
09-07-2014, 11:34 AM   #3
jcdoss's Avatar
No filter, no glass in the adapter, which also has baffles. It's a high quality "dumb" adapter. No hood either, so I'll check if that'll make a difference in the coming days. The front and rear elements are clean, but there's some junk visible on one of the interior surfaces.
09-07-2014, 09:11 PM   #4
Sounds like you are doing the right things. My guess is that this leaves two main possibilities. One is a fault in the lens. The other is reflections between lens elements and the sensor. Film is much less reflective than sensors, so older lenses were not necessarily designed to prevent such reflections. Sometimes a lens will work OK with one sensor but not another. I've run into this before; most recently with my K20 vs my A7r. It might be worth comparing results with your K30 vs the NEX.
flare, k-mount, lens, pentax lens, post, slr lens, sony
Comparing my M28/2.8 v1 and Vivitar 28/2.8 k06 Schmidlapper Pentax SLR Lens Discussion 8 01-12-2013 04:35 PM
For Sale - Sold: Pentax M28 2.8, M50 1.7, M85 2, M135 3.5 (SET) kaiserz Sold Items 13 11-06-2012 03:57 PM
Architecture Still happy with my M28 2.8 vinni Post Your Photos! 4 09-07-2012 08:26 PM
For Sale - Sold: Pentax M28/2 M28/2.8 M150/3.5 F17-28FE DA18-55WR, Sigma AF 75-300/4-5.6 75-200/3.8 xuan.s.duranleau Sold Items 8 04-06-2012 11:03 PM
For Sale - Sold: Pentax M28/2, Sigma 24/2.8 AF, Vivitar 28/2.8 yurko_yr Sold Items 7 10-24-2011 10:00 AM
All times are GMT -7. The time now is 09:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
