Originally posted by chaza01 Thank you very much for the link - there is one thing still confusing me however - does the 'A' mode on the takumar work as teh 'A' mode on a k mount? Or am I basically permanently in m mode but with no aperture held open? I cant figure if the article is referring to k mount or m42 for that last bit . Does Av mode basically continuously change the shutter speed as required whereas M requires green button? Many thanks, Charlie
With M42 screw mount lenses you basically have two alternatives, ways of using them for shooting that is .. One is when the camera is in 'M' mode. In this mode you usually follow the ligting conditions - similarly to old days and fully manual camera - you learn to 're-meter' when lighting condition change. In this mode you usually want your aperture set to whatever f-stop you want, and keep the switch on the lens itself on 'Auto' - for focusing wide open with bright viewfinder. When you are about to shoot (or re-meter) - you simply flip the switch on the lens to 'M' mode and either release the shutter or click the green button so that the camera can meter and set the shutter speed accordingly. NOTE: In this mode the ISO has to be set on fixed value for green button to work.
Another option is using the camera in AV mode with ISO set to auto or fixed value and shutter speed selected automatically by the camera. In this mode you usually keep the switch on lens on 'M' position and stop down with aperture ring while composing the shot. You can use similar technique to that one from 'M' mode - with switch on the lens on 'Auto' and flipping it over to 'M' just before you shoot - either will work OK. In this mode you are free from the need to 're-meter' with green button - which is usually the good thing, especially when you know how to employ exposure compensation or exposure - lock - to modify or lock the exposure to a specific place.
It is a bit confusing at first - but once you grasp the basics it all will all become clear and obvious
