05-12-2008, 11:17 AM   #1
Old lens, mount issue
I won a cheap lens on ebay (paid only 10) last weekend, which arrived today. All seemed interesting.
Lens is a Vivitar 70-210mm f4.5-5.6 MC, so nothing special, but in decent condition. Very clearly says P/K on the base, sold as a K mount lens. I have the K100D Super.
It doesn't mount. That is, it connects, it won't twist into place ( but I did manage to get a test shot off using it like that!). Here are a couple of (quick) photos showing the mount compared to that on my Pentax SMC-M 50mm f1.7 , you can see there is a difference.
So I am now wondering what is going on. Is there anything I can do, is it my mistake, or what? Get the feeling I've missed something.
05-12-2008, 11:19 AM   #2
Gooshin's Avatar
the solution is simple
take a file, and file away a chunk off that thing.
thats the only way.
05-12-2008, 11:34 AM   #3
MrA
QuoteOriginally posted by Gooshin Quote
thats the only way.
I'd figured out that would work as a last resort! Its a fair chunk to remove, though, and I haven't got metalworking kit anyway.
But my question, then, if that is the only way, is where is all this talk of pentax k-mount compatibility, when lenses like this exist. How does one avoid this? (ant let's avoid the obvious "buy modern lenses" answer).
05-12-2008, 11:37 AM   #4
Lowell Goudge's Avatar
QuoteOriginally posted by MrA Quote
Before you take out your saw or file, I would recommend getting a small set of jewlers screw drivers and removing the shield totally.
The lens can actually work without it, and any filing should be done off lens, so the lens is not filled up with filings.
the mod takes about 10 minutes with a fine saw (hacksaw, coping saw etc, or possily even a very sharp knife, since this part is only aluminium any way.
If you cut the shield down to size and re-install it, cover the bare metal edge with black p paint to avoid internal reflections.
05-12-2008, 11:57 AM   #5
Big Dave's Avatar
[QUOTE=Lowell Goudge;
the mod takes about 10 minutes with a fine saw (hacksaw, coping saw etc, or possily even a very sharp knife, since this part is only aluminium any way../QUOTE]
MrA,
Lowell is correct about removing the baffle,but it is most likley made of brass, which is very hard. Remove the baffle and carefully trim the baffle to height of no more then 8mm above the bayonet mounting surface. I use a dremel tool with a cutoff disk. Finish the edge with a swiss file and use a black marker to finish the job. This will allow it to clear the interior of the mirror box,including the SDM contacts. From the photos, it souldn't even be required for this lens.
Dave
05-12-2008, 12:35 PM   #6
MrA
Well that worked a treat - one borrowed razor saw later and all is well. That piece isn't brass, as it turns out, silver-coloured (so I could say steel but that'd be a guess). Lens mounts (and more importantly, perhaps, dismounts) perfectly. Now to play.
Thanks for the help.
Still interested in an answer to my question of why there are K mount lenses out there which don't fit, and how to avoid them.
05-12-2008, 12:44 PM   #7
Gooshin's Avatar
first of all it IS a Vivivtar
second, i believe the extra space that is provided for modern (and pretty much all the other lenses) with the shorter lip is... used for something, i forget what tho, anyway the Vivtar i think was designed without that in mind...
or something...
i'm just digging the odd bits of info i have in the back of my head.
05-12-2008, 01:17 PM   #8
Well that worked a treat - one borrowed razor saw later and all is well. That piece isn'tt brass, as it turns out, silver-coloured (so I could say steel but that'd be a guess). Lens mounts (and more importantly, perhaps, dismounts) perfectly. Now top play.
For compatibility try this link
Pentax Lens/Camera Compatibility - Mark Roberts Photography
I hope you blacked out the cut metal, it will cause internal reflections if you did not
05-12-2008, 02:16 PM   #9
or something...
Soligor has it on some lenses too. The lense is still PK compatible, it's just that the DLSR's has less space inside the house then the older cameras.
05-12-2008, 02:23 PM   #10
If you look closely there is a link that describes this exact issue including a picture guide for where to cut!
Flange Fix for Vivitar Lenses - Mark Roberts Photography
05-12-2008, 03:07 PM   #11
MrA
I saw that pic, which very reassuringly corresponds exactly to what I undertook earlier this evening. It's a handy site, I didn't have that link before.
Now I just have to wait for tomorrow evening when I can test the lens properly / in daylight.
05-12-2008, 07:36 PM   #12
Canada_Rockies's Avatar
QuoteOriginally posted by Zewrak Quote
It has to be cut back to fit on cameras fitted with the contacts for SDM, or used earlier for power zoom. FWIW, I have never heard of a Pentax or Takumar lens that would not fit without the fiddling.
05-12-2008, 09:03 PM   #13
TourDeForce's Avatar
QuoteOriginally posted by Canada_Rockies Quote
That makes my head hurt... Can't quite figure out what you're sayin'.
05-12-2008, 11:50 PM   #14
I have only seen this in real life once though. It shouldn't be that common. I have no clue why they did it though, was it for Ricoh cameras? I know the Soligor zoom that I saw was used on a Ricoh back in the days.
k-mount, lens, mount, pentax lens, slr lens
FF/BF issue with one of my lens Ed n Georgia Pentax SLR Lens Discussion 2 04-23-2010 03:18 AM
max lens mount/tripod mount weight soycory Pentax DSLR Discussion 1 10-28-2009 12:38 PM
Is it possible to mount an old CCTV C mount lens to my k20d? WiseOx Pentax SLR Lens Discussion 2 07-15-2009 03:01 PM
What to do lens issue foxycce Pentax SLR Lens Discussion 4 04-23-2009 04:46 PM
M42 to K mount issue winglik Pentax Film SLR Discussion 11 12-16-2008 06:24 AM
All times are GMT -7. The time now is 05:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
