Originally posted by ziscwg I think that makes sense then. The DA makes the image smaller to fit on the sensor.
Not exactly. Look at it this way….if Pentax had a full-frame camera, and you took the same exact photo twice, once with the DA50 and once with the FA50, here's what you'd see:
FA50: the entire frame would be filled with the image
DA50: the center of the image would be identical to the FA50 but it would fade to black towards the edges. You'd basically have a round image in a field of black
Now conduct the same experiment on an APS-C camera
DA50: the entire frame would be filled with the image
What you wouldn't see is that the FA50 actually had extra image outside of the frame that spilled outside of the sensor area of APS-C.
Instead of thinking of DA making "the image smaller to fit on the sensor", think of the FA spilling extra, unused image outside of the sensor on APS-C. That way, it's easier to that on APS-C, both the DA50 and FA50 take the same picture.
