The Motor Drive MX is exceedingly rare. I have seen only one Motor Drive MX in my life and I bought it on the spot. The Winder MX is much more common. I bought the motor drive used in the 1990s from Alt Camera (now defunct) in Toronto. The NiCd Battery Pack M that came with it had a dead NiCd cells, so they exchanged it for a used NiCd Battery Pack LX. When the NiCd cells inside would no longer hold a charge I had them replaced. When my MX body needed a new shutter speed controller (more than $300 Cdn dollars to replace), I bought an *ist DL and sold the motor drive and battery pack on eBay in 2005 or 2006 (I still have the photos taken with the *ist DL). Some fellow in Japan bought them. The Motor Drive was cool in that you could set the number of frames per second to your choosing (up to 5 fps)
---------- Post added 15th Sep 2014 at 04:07 ----------
Originally posted by K-Three The were two motor units available for the MX,
The motor drive either 6-AAs in a separate vertical grip that attached to the bottom, or a flat ni-cad pack on the bottom. You had to have one or the other to run it.
I owned the vertical grip (Battery Grip M) too -- it used 12 AAs, not 6! Bulky, heavy bugger. The NiCd Battery Pack LX was much less bulky, plus it had a shutter release button on the starboard end for shooting when holding the camera vertically.
