Originally posted by iamwhoiam Thanks for the KEH input. I may buy an FA 50/1.4 from them, but I am looking at some of the 50mm A, M and other lettered lenses. What's the difference? What would be the best version to go for? I am going to buy a new 43/1.9 from Adorama. I don't have any limiteds and comparing prices of new and used the new price at Adorama right now is great, at least as far as I can tell. The reviews are very good and I like the photos I have seen. If I don't like it I can always sell it at a good price. I am assuming there's a big difference between the 40 xs and the 43/1.9 not just in build but also in image quality and ability to focus.
I have been using the M 50/1.4, the A 50/1.4 and A 50/1.2 and the FA 50/1.4 and the FA 43/1.9, indeed I have the all sitting in my cupboard and some slower 50s on top. The M50 is the least desirable of the bunch. The FA keeps the lens formula of the A-series with added AF. So whether you buy an A or the FA is more a personal decision, than a question of image quality. I like the FA very much, because it's compact and lightweight. The 1.2 is much heavier and so I leave it behind much more often, than the FA.
And size and weight is a more decisive factor, than I thought in the past. I would never buy the DA 55 for its sheer bulk alone. The FA is somewhat soft wide open, as was any other lens with such a fast max. aperture at that time (with a few noteable and very expensive exceptions). The Nikons did not do better in any respect. And then there is a lot of misconceptcion around about the perceived lack of contrast wide open. Most of the exapmle images I have seen, where people complained about lack of contrast, were simply not in focus or the user did not realize how shallow the DOF is at 1.4. And as you can see with many other fast lenses, contrast will degrade massively, outside the focus plane.
So I would not hesitate to recommend the FA 50/1.4, if you need a fast and still affordable lens. For your birds it is probably more useful than the 43mm, because of the longer focal length and because its nearly an f-stop faster. Your image quality limiting factor will in all probability not be the lack of contrast, buth the shaloow DOF, when used wide open. And you will soon realize, that you need to stop down to f/4 to get good photographs of your bird, in which case the FA performs perfectly.
Ben
