I bought a damaged Sigma EX 30mm f/1.4, with the intention to fix it.
More details in the original post:
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/272999-help...based-usa.html
I had the intention to buy a replacement front glass, but i found that the damage is different from what i expected (and dismantling the objective is not as easy as i thought!).
What i know is that the front glass was damaged by the explosion of a firecracker.
From the picture the damage looked like tiny dots (indents), caused by material hitting the front glass.
That's how it looks at close inspection, but if i try to scratch the surface of the lens with my nails, i can easily feel that there are no cavities. There are small bits of transparent, glass-like material glued to the glass!
Probably when the firecracker exploded, some particles melted from the high heath, and were projected against the front glass of the lens. Of course the glass was way cooler, and the particles got stuck to the glass.
When i find fungi, or stubborn dirt, i use isopropilic alcohol. I didn't try cause i don't have any at the moment, but i will in the next days.
Somehow i feel it won't be enough. So i am asking about your "secret recipe" to clean stubborn dirt.
It must be strong enough to dissolve the stuff glued to the glass, but not enough to attack the coating.
A fluid that does not affect plastic materials would be the better solution, but i'm prepared to use a small sponge (or a cotton bud) to apply the fluid only to the spot.
Of course it must not affect the multi coating in any way.
I tried to search the forum for this kind of information, but to no avail. So i thought it was well worth starting a new thread about the subject.
Thanks in advance
Paolo
