Pentax AF 1.7x focus correction
Hi all,
I'd like to use the 1.7x TC with SMC Pentax-M* 300mm F4. Currently the TC produces a little front focus. In the camera (k5iis) I can correct it +/- 10 but it remains a little bit in front of the target. In the menu it doesn't appear as a particular lens but the camera gives me the "Apply to all" correction.
The error is constant and I can confirm it by comparing to live view CAF result.
I wonder if it is possible the error to be corrected inside the TC as it is done with lenses. I suppose there is some electronics inside the TC. I can't find any disassembling info so I'm not sure what is inside... yet.
So, can someone put more light on that issue?
Also any other ideas how to avoid the FF will be appreciated.
Thanks
