Show Printable Version 9 Likes Search this Thread
10-02-2014, 10:59 AM   #1
what is the best for landscape or seascape?
A really stupid question XD and the title says it all.
landscape and seascape with ND filter, which lens own it!
please recommend me some
what about Sigma 18-35mm F1.8?
Thank you XD
10-02-2014, 11:07 AM - 1 Like   #2
Master of the obvious
savoche's Avatar
The stupid answer would be "a lens with the focal length you need"
That said, I'm sure the (huge) 18-35 would be really nice. So would the tiny DA 15. Or a Sigma 8-16/10-20. Or...
But really, almost any lens can be the right one for landscapes. More often wide than long, but sometimes a tele is what you want. I have shot some nice landscapes with the 55-300.
10-02-2014, 11:16 AM   #3
QuoteOriginally posted by savoche Quote
Then let's say which lens is the sharpest one! XD thanks
10-02-2014, 11:17 AM - 1 Like   #4
disconnekt's Avatar
A Hard Graduated Neutral Density filter would be good, depending on where your taking photos at & the weather.
Also a Neutral Density filter would also be a good choice.
Here's a link that I think will help.
ND or Neutral Density Filters and Shutter Speed | An Explain Tutorial
10-02-2014, 11:22 AM   #5
QuoteOriginally posted by disconnekt Quote
Thanks
can you recommend me which ND filters brand is good enough?
I know Lee Filters has a very high price and I think I can't afford it XD
please around 100 or 200 bucks is ok
10-02-2014, 11:24 AM - 1 Like   #6
Landscapes (usually) are shot stopped down. To me, the most important features are that they have good colors, rendering and flare resistance. Speed (fast aperture) isn't particularly important. The Sigma is probably fine (although probably faster than is needed).
The DA *16-50 works OK (although it is more prone to flare).
The DA 15 limited is nice due to flare resistance, small size and nice colors.
If you don't need so wide, than the FA 31 limited is a great lens too.
10-02-2014, 11:25 AM - 2 Likes   #7
If you do landscape or seascape, you would usually have good light, and you absolutely want to use a tripod to get the needed depth of field and make sure your picture is as sharp as possible. Therefore, IMO, you don't need to pay extra for the fast aperture of the Sigma 18-35mm F1.8. Stopped down the IQ difference between expensive high end lenses and lower priced lenses start diminishing. That gives you lots of choices, depending on your priorities: WR or not, flexibility, willingness to change lenses etc....
Whatever you do, get a good tripod unless you already have a good one!
10-02-2014, 11:28 AM   #8
savoche's Avatar
QuoteOriginally posted by ghiaauto Quote
From the looks of it I would think the 18-35. But again, as Rondec and HenrikDK say, almost any lens is plenty sharp when you stop it down - and for landscapes that's usually what you want to do.
I would recommend looking at the works of others and check out the exif of the ones you like the most. That will give you an indication of what focal length you most likely would want, and also what f-stops and exposure times you are looking to match.
Another filter tip would be to get a circular polariser. It may not be that useful on very wide lenses, though, as the polarising effect will shift over the frame and may make especially the sky look strange. And, also as Rondec so eminently shows, the DA 15 really doesn't need a polariser. It has really punchy colours all on its own
10-02-2014, 11:29 AM   #9
QuoteOriginally posted by HenrikDK Quote
^^^this
The tamron 17-50 2.8 is worth is a look. There is one for sale in the marketplace at a good price right now (Im not the one selling it)
or perhaps the 15mm limited
or samyang/bower/ etc 14 2.8
10-02-2014, 11:33 AM   #10
pesterle's Avatar
Most of my landscapes are done with the Sigma 18-250 lens (not the macro--the previous version), with a few more done with the Sigma 10-20.
10-02-2014, 11:33 AM   #11
savoche's Avatar
^^^ and this!
And if you can't get a good tripod, don't bother. Cheap tripods are a waste of money!
10-02-2014, 11:52 AM   #12
Digital landscapes are all about fabricating your image from multiple images these days it seems. So why not just continue that tradition and use the "thumb trick" on the sun using multiple exposures to mask out any lens flare.
10-02-2014, 01:06 PM   #13
can you tell me why DA15 and FA31 are so expensive compared to Sigma 18-35 f1.8?
Sigma has the zoom range from 18-35 while the other two are fixed
Can anyone tell me what makes DA15 and FA31 very expensive? there should be something
10-02-2014, 01:09 PM   #14
I'd rather use lenses that are flare resistant if I can. Zooms aren't that bad, if you can obstruct the sun a little bit, but they certainly are more prone to flare. You can do all sorts of things -- cloning, etc to get rid of it, it just all takes more work and if you can get one photo, pass it through lightroom and color efex and be happy with the results, it feels easier to me.
---------- Post added 10-02-14 at 04:13 PM ----------
Has to do with off brand Sigma versus brand name Pentax. That said, I would look for a used DA 15 limited -- they are cheaper than the HD 15s and have nicer diffraction stars.
The place where the Sigma will really shine is in low light situations. It is really a nice lens, I just don't think of it as a "landscape" lens.
10-02-2014, 01:44 PM - 1 Like   #15
The DA 16-50 is a very good landscape lens stopped down to f8-f11, and WR if the weather is dodgy (can flare shooting at the sun). Ditto the DA 12-24 (can flare). Sigma 8-16 is also very good (again will flare). Primes, I use the DA 15 and FA 20 and 31 (the 31 is probably my favorite of the lot and very sharp at f8). I'll sometimes go longer, like the FA 77 (a great landscape lens in the right conditions) but these are the lenses I use most.
None of these are cheap, and I collected them over a long time (with much whinging from my better half). If you're independently wealthy, get them all and play. If, like most of us, you don't have infinite cash to splash in one go, I'd pick one of the DA zooms and figure out if you like the wide end or the long end most. Then you could switch to primes once you know what focal length suits you.
brand, camera, da15, fa31, flare, k-mount, landscape, lens, pentax lens, photos, sigma, slr lens, sun, xd
What is the best lens to use for birding at 500mm eq. ? jpzk Pentax Q 47 02-15-2013 12:50 PM
What is the best film body for A* 600/5.6 . . . . littledrawe Film SLRs and Compact Film Cameras 21 10-07-2012 12:18 PM
what is the best model to buy for landscape photography Unregistered Visitors' Center 15 01-12-2012 05:21 AM
For portraits and candids, what is the best zoom or prime? justtakingpics Pentax SLR Lens Discussion 12 04-16-2011 02:01 PM
Can't afford the 645D, what is the alternative for landscape. pcarfan Canon, Nikon, Sony, and Other Camera Brands 74 01-06-2011 03:25 AM
All times are GMT -7. The time now is 07:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
