Originally posted by interested_observer Here is a catalog of Sears lenses. I don't know if this is complete.
The only other idea would be if the mount was a C/Y or Contax/Yashica. It would insert and turn just part of the way and then stop. It would stop because the tabs on the C/Y mount are thicker than that of a Pentax K mount. Zeiss helped Pentax design the K mount and then designed their C/Y mount in the same way - with an increased tab thickness, so that the lenses would not be interchangeable (Contax glass on Pentax bodies). I don't know how the lens mount would be marked if its a C/Y mount.
If its really a C/Y mount, then you can use a dremel on the tabs to shave their thickness down. Rio Rico had a procedure for this. Not suggested for use on an actual Contax Zeiss lens as you will destroy its value.
That list is horribly inaccurate as well as incomplete.
AFAIK, Sears never produced lenses for some of the brands listed. It also has the same 135 listed twice, and fails to list the other two variants that I know of.
F'rnstance, there are two Sears "Yashicas" listed on fleaBay at the moment, but one clearly has PK stamped on it, and the other OM. I've never seen a Sears in a Yashica mount. Doesn't mean it may not have existed, but I would be very surprised if it did.
Sears did not produce their own lenses (they outsourced, mostly from Ricoh, Tokina, Toyo, and Samyang as far as I've been able to determine), and since they used (mostly) Pentax mount cameras rebadged from Ricoh, Chinon and, very briefly, Mamiya/Sekor, that's what they pushed for resale. They only stocked lenses with other 'big name' mounts because they had expectations to probably sell the things. If you were a small or even a medium sized camera brand, you most likely wouldn't find a Sears with your mount in it because the economics for the department store weren't there.
Roughly (very roughly) speaking, if the lens is Sears and "Made in Japan" its probably a Tokina or a Ricoh. If its Korean its probably a Samyang or a Toyo, which supposedly was actually a Sun (making it doubly rebadged).
I can't remember where the Chinons were made, but they weren't very common compared to the otehrs. Every Sears SLR was a Ricoh with the exception of the 500 and 1000 MX (those were Mamaya) and the KSX-P (that was the Chinon, and it only really came into play at the tail end of Sears' involvement with rebranding its stuff anyhow).
That 135mm macro is probably a re-rebadged Sun/Toyo. I vaguely remember stumbling over a manual ages ago before the Sears LBA bug hit me that had Toyo USA listed as the maker. I wish I'd kept it in hindsight.
At any rate, the bottom line is that Sears branded lenses had to
almost always mount on a Ricoh made SLR. Yes, they outsourced, but if that lens didn't meet Ricoh specs, it couldn't be used since they usually bundled a KS camera with at minimum a 50mm and then pushed to sell the 28mm and 135mm to go with it, as those three focal lengths were the standard primes back in the day.
Faux Edit: This came out looking way more snippy than I intended it to be.
All's cool in the pool, I just have done a lot of OCD digging on the topic at hand.
