Originally posted by kref Good question!
I think primary lens with better IQ (+ faster in low light as bonus)
Yeah budget is an issue I have like 1000$ max
So maybe what about
Pentax 15mm HD + Pentax 50mm 1.8?
WIth your budget, that would be a phenomenal combo. I disagree with the FA31 recommended above - I've now owned/tested two copies of vastly different serial numbers (it matters to some people because it identifies that they are not from the same batch), and both were immediately disappointing. The one I owned I sold within a month and the other was for the Sigma 18-35 f/1.8 "Art" in-depth review for here that is just about finishing up (sneak peak - stunning lens optically with the most problematic AF I've ever experienced in my entire photographic career -
ever, and that's with multiple copies and using the Sigma USB dock). I know I will get flogged for that and my views on the FA31, but I honestly believe it to be overwhelmingly overrated and a lens that has brought much problems to Pentax as a system because the company unfortunately rests on its laurels with that lens. I wouldn't pay $600 for one, honestly.
That aside, the two lenses you selected would run you about $800, perhaps less with the rebates/2% rewards. You might be able to do a little better shopping around. Regardless, they will offer you two truly different purposes than what your 18-135 WR offers at the moment, which is important. You go much wider (15 vs 18 is significant) and the 50mm is significantly faster than the 18-135 at 50mm (over two stops). That would give you much more opportunities than just replacing the 18-135 (which is a fantastic walkaround kit lens, not to mention WR and the other two lenses unfortunately aren't).
In addition to that, since you'll have about $150-200 left over from your budget, I'd recommend either a small tripod (my vote goes to the
Sirui T-025x, about $235 - Disclaimer - I wrote that review), or get some flash equipment and practice with taking portraits using umbrellas/softboxes. With the 50 and good lighting (even if just one light) can make stunning portraits, but you'll have to get a lot of practice
Another possibility,
and now that I think about it this would be an even stronger recommendation, might be the HD 70mm Limited (and not the 50) and instead of the HD 15 mm go for something even crazier (and cheaper) - the Samyang 8mm Fisheye. Fisheye shots are A LOT of fun with kids, and the 70mm will make just stunning portraits (way better than the 50mm).
Hope this helps
-Heie
