10-13-2014, 07:22 PM   #1
DA* Lens Performance on FF (with [HD] 1.4x Teleconverter)
So I was just wondering if anyone has tested any of the DA* Lenses (mainly zooms, it seems the primes are pretty much FF compatible anyway, although they lose AF on film due to their lack of screwdrivers) on a PZ-1 or similar camera and inform me of their performance when paired with the new HD teleconverter? Just wondering if I could use my DA* lenses as F4-F5.6 lenses on a full frame camera if it were to come out. I'm just not sure that the optical performance of the lenses is high enough, but I'd live to be proven wrong.
Thanks in advance, Joshua.
10-13-2014, 08:11 PM   #2
The DA prime lenses from 35mm and longer should work fine on a full frame camera. The DA* 55mm f1.4 is the only one that will not focus on a full frame camera, because it is SDM only, all the others are dual SDM and screw drive. DA prime lenses shorter than 35mm will vignette, but they all have screw drive so they can be focused on file cameras.
DA zoom lenses are different. Reports indicate that one cam expect them all to vignette - Wide angle zooms more so than telephoto zooms. The DA* 60-250mm f4 would have the least vignetting. You should be able to focus all of these lenses except, I think, the 17-70mm which only has DC fosucing via the SDM contacts.
Regards
Chris
10-13-2014, 09:48 PM   #3
Fogel70's Avatar
QuoteOriginally posted by seventhdr Quote
Regards
Chris
As the TC only use the central part of the the optics the vignetting problem should be minimized on all focal lengths, as long as the TC is supporting FF.
A 1.4x TC can be used for converting a APS-C lens to a FF lens, as it will use the APS-C image circle and expand it to (almost) FF image circle.
But TCs are usually optimized for long focal length so they might not work well on wide angle focal lengths
11-01-2014, 01:57 PM   #4
Mikesul's Avatar
Pentax 1.4x HD PENTAX-DA
Although there has been speculation in this thread and others about how the new TC would work on FF I do not recall seeing any clear statements of whether it really would allow APS-C lenses to cover the image circle of a FF camera. Does anyone have information on this? I suppose it could be tested on a 35mm film camera.
camera, da*, da* lens performance, ff, hd, k-mount, lenses, pentax lens, performance, performance on ff, slr lens, teleconverter
The Pentax HD PENTAX-DA AF Rear Converter 1.4X AW (and any lens) Club Mike.P Lens Clubs 425 04-24-2020 07:36 PM
1.4x HD-DA teleconverter blur derekkite Pentax SLR Lens Discussion 9 04-19-2014 04:21 PM
Image of HD Pentax 1.4x Teleconverter JPT Pentax News and Rumors 279 03-28-2014 05:41 AM
Hands-On Video with the Pentax 1.4x Teleconverter Adam Pentax SLR Lens Discussion 18 02-10-2014 06:33 PM
Sigma 1.4x EX APO DG Teleconverter -- Corner Performance Class A Pentax Camera and Field Accessories 3 07-29-2013 06:13 AM
All times are GMT -7. The time now is 06:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
