I agree with the others that if you have the 18~55 kit, there is no gain in buying old zooms, you would be better to go for some good, old, fixed focal lenses.
Here is a "fence test" I just did with the Rikenon 35~70mm you mention.
Camera jpgs out of K-01
Rikenon P 35~70mm set at about 45mm, f/5.6
https://app.box.com/s/u0u3827znxg20mc4w5d9
Pentax 18~55 Kit lens set at about 45 mm f/5.6
https://app.box.com/s/5gql6i5zobm4lknvwnvo
SMC Pentax -A 1:1.4 50mm set at f/5.6
https://app.box.com/s/c2uy48goob7ywy9sm7id
Test shows , on both zooms, the un-even focus side to side that I often see on old zooms
The 18~55 kit zoom seems to have better contrast than the Rik-P
The -A 50mm appears quite a lot better in sharpness across the plane, and in contrast, than both zooms.
As far as the Rikenon quality, the P lenses were plastic with the advantage of being light. However my Rik P lenses are starting to have glue failure and one has fallen apart.
The older Rikenon XR lenses here , on the other hand are of metal and are still in good condition, and my XR 50mm f/1.4 takes photos of similar quality to the Pentax -A 50mm f/1.4 above.
