There is a spreadsheet available to design your own lens hoods.
»ç¿ë±â
Please excuse the language of the page but look for hoodcalc.zip and at the right end of the line is the download site to click on.
This will design circular hoods which you can make.
Note it will ask for your sensor size, because the hood size is sensor dependant for vignetting.
Also note that the hood inner diameter is relitively simple, it is how big around you want to make the hood.
Lens front diameter should be the actual diameter of the front element (not the filter diameter)
you can make a hood by simply putting a tube around the filter, and this program calculates the length of the tube.
Note for lens focal length,
- because this program independantly considers the sensor size, you enter real focal length in mm not the 35mm equivelent
- for a zoom, you must enter the minimum focal length otherwise, you will get vignetting at minimum focal length.
It is possible to also make petal hoods, but that requires modifying the sheet somewhat.
