Originally posted by bimjo A pinhole.
lol I was about to say fisheye, but you got it better!
So yes, there is hyperfocal, panfocus, and other such things that beat AF. I think with Pentax, the limited primes probably have the fastest AF. I am not sure it is possible to compare "all brands", I don't think any database exists. The other problem is that this highly depends on the camera, not just the lens. And available light - in daylight, most lenses should focus quickly, at low light, things are different. An f1.4 will suddenly have a big advantage over f3.5 lenses.
And the DoF is another factors. The DA 14mm has a wide DoF, so even if focus is not perfectly on the mark, it will probably still be acceptably sharp, especially if you shoot at f8.
If you need perfect focus of fast moving objects, it is best to manually pre-focus and use burst mode or triggers.
