10-26-2014, 10:48 PM   #16
I'll agree that focusing at/near infinity is sometimes a tight bit (esp with manual lenses).
I have noticed in my particular case that my Sigma 28mm f/2.8 is sharper at distances that. My 18-55mm DAL and my Sigma 18-200mm DC. Mostly, I've found in general that primes are typically sharper than zooms. In my case, the 18-200 isn't all that sharp, but very useful. I'm planning to replace it with a 18-135mm WR, or possibly the new 16-85 'if' it is better optically and macro would be nice.
11-02-2014, 02:49 AM   #17
This weekend I had another go at the same subject with the 35mm Ltd. Slightly different weather conditions, it was more sunny. I tried different techniques as suggested by LensBeginner and here is an example of how it worked, 2.8 left vs. 4.5 right - shot with the Ltd 35mm macro
I think the trick that did it ,was moving the focus ring manually quite far out and then focusing again. I also tried the LiveView as suggested by Luftfluss, worked well too for other subjects when using a tripod; I did not have the tripod with me on this occasion, but I can see how the live view (with magnification) helps now.
So I wanted to thank everyone for posting here
11-02-2014, 04:22 AM   #18
Na Horuk's Avatar
Glad to help! Look at those photos, how much detail in each frame! Bet you don't regret buying this lens now
11-02-2014, 06:01 AM   #19
LensBeginner's Avatar
QuoteOriginally posted by mmichalak Quote
Yeah, as I said magnification really helps... especially for pixel peeping and critical evaluation of lens performance...
That hint of purple fringing at 2.8 has all but disappeared at f/4.5...
11-02-2014, 09:41 AM   #20
@Na Horuk
Ha! No I definitely do not regret it...! In fact if one thing, I am now thinking when/if I should get a wide limited, but I think this will have to wait a little bit... This 35mm Ltd is very crisp and nice from end to end, and I am looking forward to taking more photos with it.
@LensBeginner
I found that the focusing is super sensitive close to infinity, sub-millimeter moves will blur things up when magnified using the live view. But with a very steady hand, or even better a tripod, it works well...
I did a little bit of more detailed reading re. macro vs. normal lenses, and I can now see what macro lenses are all about. In comparison with the other lenses I have, (kit 18-55, Tamron 18-50, FA50/1.4 and a Sigma 10-20mm), this macro lens is mostly sharp from end to end, there is very little or not at all vignetting at the corners, and the colours are more vivid, with again little fringing.
I don't discount the other lenses at all, but this one seems to be a little bit more 'special'
11-02-2014, 10:05 AM   #21
*snip*
@LensBeginner
It truly is... however you don't need to be as precise, since you won't be viewing the image from that close...
It's a lot like pixel-peeping!
At any rate, beeing exact at 6x magnification really helps in getting a very sharp image, even when not zooming in (the kind of sharpness you perceive but can't exactly tell why).
11-02-2014, 10:13 AM - 1 Like   #22
kh1234567890's Avatar
The DA35 Macro is OK at infinity but if you don't watch it the shots can end up a bit 'flat'. Get close in, that's where it excels - it is a macro after all ...
11-02-2014, 10:15 AM   #23
QuoteOriginally posted by kh1234567890 Quote
Hey that's not flat at all!
An awesome photo...
Post liked.
35mm, 35mm 2.8, arms, coat, crops, focus, k-mount, kit, lens, ltd, macro, pentax lens, photos, shot, slr lens, tamron, view
Pentax 35mm f2.8 Ltd vs Sigma 18-35mm ART pentaz Pentax SLR Lens Discussion 3 07-31-2014 02:01 AM
35mm Comparison: DA35 f2.4, DAL 18-55, DA 18-135, Tamron 24-135, F 35-70 mgvh Pentax SLR Lens Discussion 2 07-29-2013 02:49 PM
Pentax DA 35mm 2.4 vs Takumar 28mm 3.5 vs Zeiss Flektogon 35mm 2.4 vs 18-55 AL -kb- Pentax SLR Lens Discussion 5 07-01-2013 04:25 PM
Tamron 18-200mm vs Pentax 18-35mm and other lens options jrhineberger Pentax K-r 9 11-12-2011 06:58 AM
All times are GMT -7. The time now is 12:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
