Originally posted by DragonLord What are your thoughts on this issue? Can you reproduce it? If so, do you find it a serious problem?
I get the same at the same settings. Mine vignettes about as much in the upper corners as yours does in the upper right, and in the lower corners as yours does in the lower left. That is without the hood, so that doesn't come into play.
Not really a practical problem for me. I have noticed some vignetting in some of my shots around 100mm, but usually I'm at 135mm if I go close to MFD. No problems with vignetting there.
Thanks for sharing, though. This issue is easy to work around once you know it's there. Just as I try to avoid 18mm; this lens (at least my copy) gets much better by zooming in just a notch.
