When it comes to vignetting, the Pentax 18-135mm is at its worst near 100mm. In fact, I've identified
mechanical vignetting most pronounced at 100mm when the lens is at or near minimum focusing distance. In other words, the extreme corners of the image
literally fall outside of the image circle and become totally black. This phenomenon is most evident when the lens is stopped down to f/16 or further and is only exacerbated by the Shake Reduction system, which can take parts of the image further outside the image circle.
What are your thoughts on this issue? Can you reproduce it? If so, do you find it a serious problem?
—DragonLord
