Originally posted by JanG
What would you do?
I feel that at the end of the day, it can only be your call.
Only you know whether you can live with the percentage of bad shots this copy of the lens is delivering.
Despite the fact that some people in this thread can now only report on the negative aspects of the lens, despite having
substantially praised the lens for its optical performance potential in the past, there is no denying that outside adverse conditions, this lens can deliver superb results and that it may be acceptable to live with some uncertainty about focus accuracy. Note that the Sigma lens dock may help to address focus issues to some extent, but that an erratic component appears to remain even after calibration, at least for some copies (I am in no position to ascertain that all copies are affected by the erratic focus behavior, nor is anyone else here).
If I were you, I would try to come to an arrangement with the dealer to try another copy of the lens with the fallback option that you could get back your original copy in case it seems to be a perfect copy with the exception of the focusing issue. If you are lucky, then perhaps you get a copy whose focus failures are entirely within the normal range of Pentax PDAF performance (it is not perfect and for technical reasons absolutely cannot be perfect for lenses with an aperture wider than f/2.8 (<- the widest base of the PDAF system, with most focus areas only achieving f/5.6 precision).
For every person who claims my "so and so genuine Pentax lens never misfocusses, there is another person reporting the occasional misfocus result from wide aperture genuine Pentax lens). So don't expect 100% perfection. An 80% success rate is not what one would normally expect, though.
Would be good to be hearing back from you, should you decide to try another copy.
