11-12-2014, 05:37 PM   #61
MadMathMind's Avatar
QuoteOriginally posted by AtitG Quote
When pentax rated their PDAF sensors at 2.4. I guess they already knew that their manufacturing tolerances would only create a system that will work reliably with lenses 2.4 and slower. I am under the impression that the sigma lens will have focusing issues since all AF happens at 1.8, and it only closes its aperture after AF.
Large apertures are always better for autofocus systems, as there's more light available. As pointed out, the FA Limiteds don't have major issues like this and those are all 1.8 (or 1.9 for the FA43) as well.
As I pointed out above, the f-rating has more to do with the limitations of precision of the AF system than anything else. The system just can't guarantee that it can focus to within the DoF of the low f-stop so it can't guarantee that it will focus correctly. Something in the image should be in focus, just not probably what you aimed at.
11-12-2014, 06:42 PM   #62
Digitalis's Avatar
QuoteOriginally posted by MadMathMind Quote
Usually large apertures are good for AF systems however in the case of an f/1.8 zoom it doesn't seem to help at all. The FA limited lenses aren't zooms, primes are better suited to the AF calibrations on Pentax DSLRS - the Sigma lens dock allows for AF adjustments at different focal lengths
11-13-2014, 05:25 PM   #63
Large apertures are always better for autofocus systems ...
Not always. While large apertures may pass more light, they can often deliver other problems - including greater softness and CA. All of which won't make AF better.
The corrective optics within the AF module of the camera can try and deal with some of those problems, of course. But it would be better if they weren't there in the first place. Pic related - the K-3's AF module.
The Sigma 18-35 seems to be well corrected for most forms of CA and is pretty sharp wide-open, so the issue of lens softness and CA disturbing AF may not apply to it that much.
11-13-2014, 05:37 PM - 1 Like   #64
I am starting to see the issues with focus. I don't see them past 2.8, probably because there's enough DoF to cover the misses. Even at f/2.2 or f/2.5, I don't see a huge percentage of misses, at least not terribly more so than what I saw with my F50 f/1.7 (the FA50 f/1.7 seems to be quite an improvement, though). I just never really shot it much at f/1.8 until this past week, where I used it quite a bit more.
Still, I have the dock coming from Japan now, so I can use it to take a look at my lens. I definitely get a lot of in focus shots even at f/1.8, so my issue isn't nearly as bad as what the review says, but it is a high percentage of misses. Maybe half?
11-14-2014, 10:33 AM   #65
I had focus issues at F4. It was not front or back focus. The whole scene was just a tiny bit out of focus. Strangely enough, recently I had almost no issues with focusing.
Download the images to see them at 100%.
11-14-2014, 01:20 PM   #66
QuoteOriginally posted by Stagnant Quote
The images you've posted and viewed at 100% appear to show unusual focus across the images. IMGP7844 appears to have front focused by quite a bit as the water in front of the ship is in crisper focus that than the ship. And the right side seems softer than the left side. IMGP7766 is harder to decipher. The sharper center is to be expected for most lenses though the differences on the sides would be something to explore. The right side seems to be weaker than the left. You might want to do some more testing to see if you have a decentering issue.
11-14-2014, 02:34 PM   #67
QuoteOriginally posted by Dice Quote
Speaking about focusing issues, I found it to be more reliable at F1.8 than at F4. Haven't experience focus quirks recently.
I did notice some decentering on my copy. I had no chance to get it serviced, because I needed it badly.
11-14-2014, 05:34 PM   #68
Digitalis's Avatar
I had the same problem - the de-centering was slight and was exacerbated by the AF inaccuracies of the lens, that the official repairer in my country refused to do anything to my lens. They "tested" my 18-35mm f/1.8 on a pentax K7 handheld at f/8 ISO 400. Sigma QC strikes again
The bottom line is, that there are things that can go wrong with the production of these lenses.
11-16-2014, 01:23 AM   #69
s76
Hi Digitalis.
I have now calibrated three first distance with good results. What distance did you use for last point? Marking is near 2m, but how it will work to 10 or 50 meters?
Sami
11-16-2014, 02:14 AM   #70
Digitalis's Avatar
QuoteOriginally posted by s76 Quote
I used a high precision calibration chart to find the point of optimal focus at all the set distances. if you get the calibration right at 2m and infinity everything between those points should be reasonably accurate.
11-16-2014, 05:04 AM   #71
s76
Thanks!
May I ask how did you infinity calibration test. I am wondering about distance, or did you use multiple distances. Or is it better to do with comparing af with live view af? My lens is now good to 2 meters, but infinity focus is not so good.
I know that it's hard to focus infinity right at f1.8 for lens, but I have taken great and sharp infinity photos with live view. I just want to do same via view finder.
Sami
11-26-2014, 07:49 PM   #72
Enrique S Toso's Avatar
Any news with the af issue? Is it a hardware production problem? Where can i test and buy this lens in fort worth or Dallas region in Texas?
Ty!
11-27-2014, 09:07 AM   #73
Digitalis's Avatar
That would be one way of doing it. I actually did it because in AF mode the lens would undershoot infinity, it was really simple of figuring out how much I needed to correct it*.
QuoteOriginally posted by Enrique S Toso Quote
The focus issues still persist, no hardware or software solution has been offered by sigma for any lens mount.
So my advice is: if you wish to buy this lens I strongly recommend getting the lens dock along with it.
* I live near the beach, so infinity focus subjects are very easy to find.
12-23-2014, 05:03 AM   #74
Sorry for insist...but...any news or rumor about a solution for this problem?? Ty!!
12-23-2014, 05:30 AM   #75
Digitalis's Avatar
Nope - Sigma hasn't made any statements regarding focus accuracy and this particular lens.
af, aperture, art, art focus issues, f/1.8 art focus, ff, focus, issue, issues, k-5, k-mount, lens, lenses, pentax, pentax lens, shots, sigma, sigma 18-35 f/1.8, slr lens, thread
The Sigma 18-35 f/1.8 Art club scratchpaddy Lens Clubs 112 11-29-2018 05:05 AM
Sigma 18-35 1.8 art vs HD DA 20-40mm F2.8 - 4 Limited DC WR jrcastillo Pentax SLR Lens Discussion 111 09-22-2015 03:02 PM
Sigma ART 18-35 1.8 and K-30 jrcastillo Pentax K-30 & K-50 36 07-28-2014 09:42 AM
Sigma 18-35 f/1.8 vs the Pentax DA 16-50 f/2.8 someguy42 Pentax SLR Lens Discussion 9 12-06-2013 12:02 AM
All times are GMT -7. The time now is 11:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
