11-04-2014, 09:09 AM   #1
techmulla's Avatar
DA* 55 won't focus
so i turned my camera after many days, and when i press focus .. nothing happens
my camera is k5 and my lens da* 55.
is it an sdm failure?
//ysf
11-04-2014, 09:13 AM   #2
First try to clean the contacts on the lens and on the camera to make sure it's not just dirt or film oil. Use a dry microfiber cloth works very well.
11-04-2014, 09:13 AM   #3
aurele's Avatar
Make sure :
- AF switch on the lens is on AF
- AF switch on the body is on AF (AFC or AFS)
if nothing change so far, then :
-remove the lens, and put it back again
if nothing change :
- remove the lens, clean contact, try another lens.
If nothing change :
- I can't help you any further
11-04-2014, 10:04 AM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by aurele Quote
If nothing change :
- Battery charged?
11-04-2014, 10:12 AM   #5
techmulla's Avatar
did all of this, but didn't work .. went through plenty SDM posts this forum and there was a tip which worked for me ..
try doing the manual focus while pressing the shutter release .. this kicked the motor back in action ..
thanks for the help guys .. saved me a scare.
Make sure :
if nothing change :
If nothing change :
11-04-2014, 11:16 AM   #6
QuoteOriginally posted by techmulla Quote
This should not be needed. If your lens is still under warranty, I would request service.
11-05-2014, 01:57 AM   #7
techmulla's Avatar
unfortunately, it is not. maybe i should count the days to SDM failure then?
11-05-2014, 08:16 PM   #8
Glen's Avatar
Probably yes. I sold my last SDM. The first sign is stiff focusing after a period of non-use. After that there may be strange sounds and finally no sound and no focus. The good news is that Pentax's new lenses (motorized) use DC motors which are as dependable as they get.
camera, da*, focus, k-mount, pentax lens, slr lens
DA* 16-50 stuck - won't zoom or focus amoringello Pentax SLR Lens Discussion 23 12-13-2016 11:05 AM
My K20D doesn't won't focus Slowpoke Rodriguez Troubleshooting and Beginner Help 5 01-06-2013 08:04 PM
K-5 and DA*50-135 won't focus in LIVE VIEW. bossa Pentax K-5 6 03-08-2012 04:02 AM
DA 50-200mm Won't Focus Infinity Tobman Pentax SLR Lens Discussion 6 12-20-2011 10:39 PM
DA* 50-135 won't focus on K10D beyond 90mm fsdogwood Pentax SLR Lens Discussion 8 10-20-2008 10:16 AM
All times are GMT -7. The time now is 12:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
