11-05-2014, 02:11 PM   #1
Extension tube recommendation
Extension tube recommendations anybody? Really don’t like the idea of a reversing ring (I do have one) but was thinking of getting a set of tubes to use with my sigma 70mm. Any and all advice and know how greatfully recived
11-05-2014, 03:16 PM   #2
glasbak's Avatar
The sigma 70mm has no aperture ring (macro lenses without aperture rings are very limited in their use on bellows/reversed etc.), so you need tubes with A contacts.
11-05-2014, 03:22 PM   #3
QuoteOriginally posted by glasbak Quote
, thanks this had been mentioned to me before.. seem very scarce on the ground
11-05-2014, 03:26 PM   #4
maltfalc's Avatar
buy a scratched teleconverter on ebay and unscrew the glass.
11-05-2014, 04:01 PM   #5
jatrax's Avatar
I have one available already deglassed if you are interested. PM me if you want and we can discuss.
11-05-2014, 04:07 PM   #6
Bob from Aus's Avatar
The teleconverter on its own can also be OK.
I have an older pentax set of rings that will do the aperture. You could try and get a second hand set - but must be able to do aperture.
Oops sorry this is for the Q - looks like they removed the K mount - however you should have a look. The link I saved no longer goes to the K mount product
(Pentax Q Auto Extension Tube Set | Macro | SRB-Photographic.co.uk there are a number of people on this blog that have used some of their products, so check the thread first)
11-05-2014, 04:15 PM   #7
QuoteOriginally posted by Bob from Aus Quote
They tried K mount extension tubes with screw drive,
but it seems that they didn't really work that well,
so reputable dealers stopped offering them.
11-05-2014, 06:58 PM   #8
baro-nite's Avatar
In my experience the Sigma 70 does not match well with the typical A-type teleconverter used to make an extension tube. The Sigma (and some other DA lenses I've tried) will not show the correct aperture on the TC. I think it needs the 7th contact to work correctly.
11-05-2014, 07:18 PM   #9
QuoteOriginally posted by baro-nite Quote
Thank you, that was the bit of info nobody seemed to supply even my local pentax specialist
11-05-2014, 08:00 PM   #10
QuoteOriginally posted by maltfalc Quote
^ this post is going to drive prices of scratched teleconverters up. good idea.
11-19-2014, 02:01 PM   #11
maltfalc's Avatar
QuoteOriginally posted by rrstuff Quote
i have some for sale.
11-19-2014, 02:13 PM   #12
pacerr's Avatar
If you need to explore the effect of extension rings simply cut various lengths of paper towel/toilet paper cores and temporarily position the lens to see/compare the results.
11-19-2014, 02:36 PM   #13
Can it be something else?
I used A-type teleconverters (deglassed to make extension tubes) with a few Sigma lenses. The tubes were a variety of 6-contact and 7-contact types. All worked OK.
The 6-contact type, if the matting surface with the camera is anodized, needs to have the area where the 7th contact would be scrapped to make ground contact (a strip of aluminum foil also works).
11-20-2014, 07:40 AM   #14
baro-nite's Avatar
QuoteOriginally posted by SOldBear Quote
Certainly could be something else, but I would't know what. None of the TCs I've tried this with have had the anodized surface. Have the Sigma lenses you've tried had aperture rings? The 70 macro doesn't.
Same issue with the few DA lenses I've tried. DA* lenses work fine with an A-type TC, however.
11-20-2014, 10:10 AM   #15
I just tried a 6-contact tube with the lenses in my signature. All of them worked fine. The only Sigma that has aperture ring is the 135-400.
The DA lenses worked OK too.
Please read this post regarding 6-contact vs 7-contact tubes.
extension, extension tube, k-mount, pentax lens, slr lens, tube
Helicoidal Extension Tube xoxixox Pentax Medium Format 3 10-14-2014 01:52 PM
Macro Extension tube woes Undot Photographic Technique 12 09-17-2014 02:00 AM
extension tube mikol Welcomes and Introductions 8 07-16-2013 12:41 PM
Extension Tube K 100 Cloapex Pentax DSLR Discussion 8 03-11-2013 12:13 PM
Extension tube recommendation for K-x Ramesh Pentax Camera and Field Accessories 3 10-19-2010 04:15 PM
All times are GMT -7. The time now is 01:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
