Originally posted by Sudhakar I am pretty excited to get my first M42 baby super Takumar 28/3.5. Also received original Pentax adapter. Easily mounted and screwed the lens. Tried couple of shots and Av mode with lens set in Auto switch mode and couple of shots in Manual mode with green button pressed. Looks like I need to get used to exposure compensation as all shots are under exposed. I will do home work.
setting the lens switch to 'A' is not recommended since the lens will always stay fully open, only the 'M' setting allows for variation of aperture settings.
I am using the *istDs which is metering better, but on all the K models including yours a ex. comp. of about 1.5 will be necessary.
Originally posted by Sudhakar My main concern now after using first M42 is, I do not see focusing hexagonal symbol now. From the research on net, people say that m42 with dSLR shows this beep sound and hexagonal confirmation. But for me it is not showing. What am I missing here?
thanks in advance.
edit: I use pentax K100Dsuper
focus confirmation should show, both peep and hexagon, some of the settings on the camera is not correct yet. I don't remember out of my head which it is but many knowledgeable people have been posting in this thread so it won't be long before somebody told you, if not I'll come back and will try to help again.
the 28/3.5 is a very nice lens for sure, some recent examples from Kathmandu:
