Originally posted by abmj Would you think that a very cheap lens is optically the same as a high-end lens by a reputable company? The differences are in better materials, better quality control, better grinding/polishing and better coatings. A $4.00 filter won't be much better than putting a piece of Saran Wrap over the front element. Ok, I exaggerate a little.
Bottom line, it pays to pay for quality work. If you are going to put something in front of your precision, high-quality lens, you should probably match the quality of the lens as close as you can. Otherwise, you just reduce the quality of image the lens transmits.
I, respectfully, disagree. There are major differences between the construction, design, and materials, for a cheap and expensive lens. That's why you can expect the expensive lens to perform much better. In the case of even a cheap UV filter I would expect the glass to be very flat and true, so that distortion would be negligible. Even if it didn't have super-dooper coatings I would still expect that it would perform very well and be more than adequate for even advanced photographers.
One respondent said, above, that some filters are cheap because the sellers operate at a lower profit margin. But $4 including postage, is giving it away. What profit can they make? What's their motive?
---------- Post added 11-07-14 at 06:45 AM ----------
Originally posted by alfa75ts I don't like skylight or UV filters on digital but that's just how I feel.
In high contrast situations, lights at night or shooting the moon, it's easy to see the reflections of light bouncing off the sensor and back off the inside of a filter.
This actually happens in all shots but can be hard to see.
If you want to scare yourself look at the moon offset to one side in live view with and without a filter.
If you must use a filter at least get one coated both sides to reduce reflections from the inside.
Thanks Alpha. That's one valid reason to not use a UV filter, especially if the cheap filter is more prone to this problem. But is it?
---------- Post added 11-07-14 at 06:47 AM ----------
Originally posted by SpecialK Use a hood always, and a lens cap when not actively shooting. I avoid plain filters, particularly cheap ones.
Hi SpecialK. What is your problem with cheap plain filters? Is it a generic problem?
