Hello all
I recently got a FA*600mm F4 lens and already have a few other long lenses as well to add. I have not had time to do s stationary test yet but Kevin (
KevinR - View Profile - PentaxForums.com) did do a few before shipping the lens to me. He also tested the lens with the new teleconverter that he has.
If there is enough interest I will also do a static test of the FA* 300 vs the FA*600 with my old 1.4X and 2X converters. I will want to tie up with a fellow pentaxian that's close-by that has the new DA560mm and his new converter to do some test.
Lens Test:
Native view with DA* 300
The view comparison only cropped horizontally. (ie full vertical FoV)
Read more at:
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/267012-some...#ixzz3IZ9eyskK
And then a zoom in on the angle graduation plate with each image resized so that the view is the same number of pixels in each case (600x600 from 300x2.8TC or 600x1.4xTC as default view)
And then a zoom in on the angle graduation plate with each image resized so that the view is the same number of pixels in each case (600x600 from 2.8x TC as default view)
He tried the stacked 1.4x and 2x converter but could not get a stable enough photo to post.
Here is the whole post as well (
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/267012-some...nce-tests.html)
---------- Post added 11-09-2014 at 01:04 PM ----------
Review:
Now in terms of the 600mm. The weight is something to get use to but is manageable. I attached it also just directly to my big monfrotto mono pod and this combo seems to work well and offer some mobility. I also now ordered a Wimbley style head with adapter for my car.
Secondly I also found that the lens hood design could have been better. It is a bit tight and if not extended correctly can scratch the barrel. Also being a silver lens it is prone to being scratched but on the 600 the paint does seem thicker than my FA* 300 F2.8. I am also going to make myself some lens covers like that of the 600mm that recently sold that was made by the owner
kulas3VII - View Profile - PentaxForums.com AF Test:
The AF is very fast and with the new K3 I can get some degree of Birds in flight shots. you can also limit the focus range to increase the AF further. I have not had a lot of time to practise yet but here is a composite showing the FPS and AF speed. Note one photo I left out as it was to tight in composition.
The sharpness is Excellent and I will also post some shots taken with lens.
---------- Post added 11-09-2014 at 01:34 PM ----------
Sample shots
shot at F7.1 1/640s Iso 125
full size here
https://dl.dropboxusercontent.com/u/85506286/IMGP6849%20copy%20-%20Copy.jpg
Croped on bird
