Originally posted by GateCityRadio It rendereds better bokeh and the "glow" and "softness" at wider apertures is great for portraiture, which is what this lens shines at on APS-C.
Beautiful shots! That being said, "glow" at wider apertures is generally considered to be a fault, not an attribute, and is one of my minor complaints about the DA 50/1.8.* Fortunately it is a problem mostly in strong light and is less a problem otherwise. As for the bokeh, I have not been particularly wow'ed except that that iris outline is a bit nicer at wider apertures due to the curved blades.
BTW...your shots above don't show the glow I am concerned about.
* There are lenses that are designed for that effect and are usually labeled as such (e.g. "Soft"). I also have a couple of lenses that glow quite readily, but I always qualify that property before recommending them for general use.
---------- Post added 11-16-14 at 03:42 PM ----------
Originally posted by LensBeginner as circle of confusions will be magnified differently
"Circle of confusion" is not something you see
per se. In practice, it is a semi-arbitrary value applied as part of the DOF calculation. It represents the diameter of
acceptable blur for a point source at given distance from true focus. At various times different lens makers (most notably Zeiss and Leica) have used different values for calculating the DOF scales on their lenses even though the format might be the same.
Magnification is part of the DOF picture and in fact magnification of the final viewed image is one of the three factors that do not cancel out. The other two are absolute aperture and viewing distance. Focal length and capture format are important, but ultimately incidental.
---------- Post added 11-16-14 at 03:58 PM ----------
Originally posted by kh1234567890 Even that is debatable in practice - view this shot from 12" distance and then from 18". Is there any change in DoF ?
I love it when people other than myself point this out.
Here is another test:
Compare this image to my avatar. Which has greater DOF?
Yes, both are derived from the same original file.
