11-10-2014, 05:44 AM   #1
Small Zoom Lenses
What are people's favorite small zoom lenses? The most obvious are the Pentax 35-70 F/3.5-4.5 and Pentax 20-40, how do they compare in size, weight? Are there other small zoom lenses that people like to use?
What about a zoom lens that when locked is small? I've heard that the 35-70 is 2", are there any other lenses this small?
11-10-2014, 06:08 AM   #2
flaviopetrone's Avatar
I have got a Pentax F 35-80 and it is very small and light, but not a very great quality lens.
11-10-2014, 06:09 AM   #3
yup pentax F 35-70, i thinks the smallest zoom lens and cheaper than 20-40 and 35-70 have macro feature that helps a lot, and that lens also fast enough and a good lens to handle noise than 18-55
11-10-2014, 06:11 AM   #4
The DA 16-45 is also quite compact and well regarded optically. I don't have personal experience with that one, though.
Regards,
--Anders.
11-10-2014, 06:15 AM   #5
QuoteOriginally posted by asp1880 Quote
Regards,
--Anders.
The DA16-25 is huge compared to the 20-40 or the 35-70 and or 35-80.
11-10-2014, 06:57 AM   #6
QuoteOriginally posted by mixberry Quote
What do you mean by handle noise? I'm picking my copy up tomorrow but I've heard that it is pretty good optically, especially stopped down to f/5.6. I've also heard that it is small; I guess I will see tomorrow!
QuoteOriginally posted by Macario Quote
So that's the question, the 16-45 is comparatively huge, huh? That was what I thought, compared to the smaller zooms. But are there any zooms that are small at their widest setting? For example a 28-90 or something.
The 35-70 is great because of the size, a 35-80 doesn't really add that much. The problem with the 35-70 isn't the size or image quality (from reviews) but the wide end; if it were a 28-60 or 25-50, it'd be better. Really, the 20-40 with the K-01 makes a lot of sense; it's a shame they didn't come out at the same time.
Even the 20-40 is bigger than the 35-70 though, correct? A 18-36 f/4 that was smaller may have been better. Most people are fixated by low f/stops though.
11-10-2014, 07:00 AM   #7
20-40 is all metal but surprisingly light in weight. It's a short range, but a surprising amount of shots are right in there. The 20mm end is nearly 28mm eq., and with the K-3's 24mp sensor, crop-in's effectively extend the 40mm end a good deal.
11-10-2014, 07:01 AM   #8
QuoteOriginally posted by jk333 Quote
I think after seeing those Sigma primes and zooms... most Pentax zoom lenses seem small in comparison
11-10-2014, 07:30 AM   #9
The Tokina SD 70-210mm F4.0-5.6 is a pretty compact zoom lens. Smallest 70-210 I have ever seen, not sure if there is anything smaller or not. It is manual focus and pretty good quality.
11-10-2014, 07:44 AM   #10
reeftool's Avatar
Noise isn't caused by a lens but by the camera's sensor. The higher the ISO setting, the more noise. What he is probably mentioning is the aperture range of the F 35-70 is f/3.5-4.5 and the 18-55 kit is f/3.5-5.6 which makes the F a little bit faster on the long end. The difference is minor and in the real world probably not enough to cause you to bump your ISO up. Noise increases when you raise your ISO and 90% of the time, you would be using the same ISO for either lens as the difference is 1/2 stop and only on the long end. From my experience, the F 35-70 is a little sharper wide open and has a very pleasing bokeh. The lens isn't as handy as a walk around on a digital body but it's a good lens and because it's relatively inexpensive, a lot of people will recommend it. It's much noticeably smaller then the 18-55.
11-10-2014, 08:24 AM   #11
MJSfoto1956's Avatar
I think "huge" is a bit of a stretch.
Here is the 16-45mm in an OpTech USA 2.5" deep accesory case along with other Pentax lenses for comparison. I find it to be a great little lens.
YMMV
Michael
11-10-2014, 08:50 AM   #12
bassek's Avatar
In addition to the previous the F24-50is small. As is the F70-210. The DAL 18-55 is light...
Seb
11-10-2014, 10:17 AM   #13
After the DA 20-40, the best of Pentax's small zooms may be the FA 20-35 f4, which weighs only 245 grams and is only 7 cm in length.
11-10-2014, 11:10 AM   #14
dadipentak's Avatar
A 24-50/4
11-10-2014, 11:27 AM   #15
ChristianRock's Avatar
QuoteOriginally posted by MJSfoto1956 Quote
YMMV
Michael
Your signature doesn't show that lens anymore, did you sell it because it didn't compare well to your Limiteds?
Regarding small zooms - a few kit lenses from the film era are quite small, but they're usually slow, and a lot of times the quality isn't there. Though a lot of old Pentax lenses can be quite useful in the right hands - I've seen some very good shots from the F 35-105 and the F 35-135, for example, and they're compact as far as zoom lenses go (not like the 35-70 which is small as a prime).
k-mount, lenses, pentax, pentax lens, slr lens
best small lenses for K-01 kevwil Pentax K-01 69 04-29-2013 09:29 AM
K30 K5 K5II pancake or small lenses desmojack Pentax DSLR Discussion 8 12-19-2012 01:29 PM
Looking for a small and light zoom atekant Pentax SLR Lens Discussion 11 06-02-2012 06:42 PM
Small but high quality tele zoom? orangezorki Pentax SLR Lens Discussion 17 03-17-2012 12:20 AM
wide angle or small zoom? nodretep Pentax SLR Lens Discussion 5 03-18-2009 07:16 PM
All times are GMT -7. The time now is 01:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
