Originally posted by crewl1 There's another Tamron f2.8, the 28-75mm can also provide low light capabilities and give you a little longer reach for the ballet.
+1 for that. I find it an ideal lens for indoor events. Unless I was in a really cramped space taking group photos, (and those would be posed so your 18-135 would be fine), I'd rather have the lighter weight and 50-75mm on the long end than the 16-28 on the wide end (not to mention I'm pretty sure it's cheaper)
On the ballet, area you going for group shots, full body of a single dancer, or detail shots? Like, is your 18-135 OK so far as framing goes and you just don't feel it's fast enough?
I haven't shot much ballet, just a couple of public outdoor events where flash would have been fine, but for the more recent one, I used my 50-135 at about f/4-5.6 (shutter speed 1/400-500). (The first one, I had just gotten my 55mm f/1.2 and was trying to use that. It made for some really interesting artsy shots, but it wasn't really long enough, so I had to crop a lot)
I think if I was doing it regularly I'd probably use a tripod and my 60-250, possibly with a teleconverter attached, depending on distance from the stage to get a good height.
If you're comfortable at 135 and less, the 50-135 is a beautiful lens that you can probably get used within your budget.
If you need more distance, look into a 70-200 2.8 from a third party, or the 55-300 if you don't mind it being a slightly smaller aperture. You can get the DAL version of that used really cheap.
Alternately, usually the first lens you'd get to compliment a consumer zoom is a fast prime - you could probably get both of the non-limited non-macro non-FA 50 and 35mm primes for under your budget.
At any rate -- consider used lenses. They're still excellent lenses, and they're much less expensive.
