I´m hinking of buing a volna 3 or a Biometar 80/2.8 and adopt to my Pentax K-5. They can easily be found very cheap in Europe where I live.
Only thing i think about is if the best hing is to have 'Pentacon 6 to M42 adapter or a Pentacon 6 to PK-adapter.
The think i like with M42 is to shoot in AV-mode and I tend mostly to shoot wide open or stopped down one or two notches and then the viewfinder is bright enough to shoot this way. I guess if I buy a Pentacon 6 to K-adapter I will probably have to press the green button all the time as a PK-manual??
If i understand it correctly sharpness and abboration would be good. I wood just use the center bit of the lens due to a smaller sensor but the FOV would be different off course.
Also i would need a little middle ring to put the lens to the correct sensor distance?
Found the distance to be 74.1
