Originally posted by maxxxx Is this normal for this lens?
No, it is not normal, assuming you are using a Pentax dSLR. The maximum aperture detection is passive and is based on the pattern of contacts on the lens mount. A f/1.4 lens has a different pattern of contacts having continuity than a f/2.8 lens. The pattern for f/1.4 is one off from that of a f/2.8 lens
(100*00 vs. 000*00) (100*01 vs 000*01). It appears the camera is detecting continuity on contact R1 (furthest towards bottom) where none should exist.
You may want to clean the contacts on both body and lens and see if that helps. Also check to make sure the lens is fully mounted.
---------- Post added 11-13-14 at 08:55 PM ----------
BTW...If you have an ohm meter you can test continuity between base and contacts on the lens. There is no harm in doing so. My mistake...it is the body that can be tested this way.
