My first experience with this lens in bright sunlight as also not that great, but stop down and it gets much better. The problem with the XS version is that it has 27mm filter threads, so it is difficult to find a lens hood. Maybe some step up rings. Also, if you lose the lens cap, don't buy a genuine replacement, it is very expensive. There are cheaper knock offs available online. I just bought a Massa 27mm UV filter that I use instead of the lens cap. It has the benefit that I can just shoot without removing it, if I dont have the time to unscrew it - it barely affects the IQ.
But don't worry about flare and fringing, the lens has a learning curve, and once you get it, you get it
