Originally posted by panoguy Trust me on this, there is nothing in the practical use of a panohead that requires $700. I've lost count of how many panoheads I've owned (I think I have 5 right now, maybe more if I go digging), including a $1200 "precision" beast. While the really expensive ones don't add much, if anything, to the panoramas I make, the really cheap ones can be a nightmare if you shoot more than occasionally.
The biggest issue with the heads you've pointed out is not the arms or controls, but the rotator on the bottom. Life is so much easier shooting panos with a good rotator! Sloppy clickstops or a stiff rotation lead to toppled tripods or re-shooting an entire pano due to vibration blur. You'd be better off with a wider lens and no rotator at all!
Personally, I've settled into Nodal Ninja heads, and their NN3 is far lighter, smaller, and likely more precise than either of the two you've linked to,
and the full package with rotator and case starts at $190. That's $55 more than the first one, and probably 2lbs lighter and definitely better built. (Or even as low as
$160 for a "factory irregular" model.)
Greg's Panosaurus (mentioned above) is a good choice if you are okay with a non-clicking base and don't change lenses often, since it's a little hard to adjust.
Thanks ! The main lenses I will be using are 20mm , 28mm , and 35mm....... all SMC-K Pentax.
My main concern is getting a smaller head/unit that is somewhat compact and tight.
I could care less if there is click stops in every configuration or not. As long as it rotates tight , has marks at the 5 degrees and more , and an indicator.....it matters not to me.
Im in Pano head overload right now and just might hold tight untill I get it all figured out. Mainly I will be using horizontal in portrait @ 3-6 frames. But....would like the ability to do Rows as I learn more.
I think just a good Ebay $70 Rail would make me happy at the moment ! At least I would have a solid landscape platform.
I just noticed that IS a good deal for the factory Irregular ! Thanks !
---------- Post added 12-02-14 at 11:24 PM ----------
I just bought the Nodal Ninja 3 MKII. (in Cart anyway)
I got a factory second kit for $149 and then found out I have a PP coupon for $10 off !
Ordering it at 6AM as soon as my check clears.
What did it was Panoguy's links.....When I saw the video of it at the Grand Canyon and saw it in movement that did it ! Its quite compact , and the price was right.
Thanks guys for helping me decide.
I want things to be.......... KISS....KEEP IT STUPID SIMPLE......this does it !
