12-06-2014, 02:43 PM   #16
QuoteOriginally posted by henne Quote
I would consider the older K/M versions of the 400mm as well. They will cost you less than the A, and you will not miss the A position much, as such a long tele lens is used rather wide open anyhow. One can even use the Av mode of the body, maybe applying some exposure compensation on stopping down. This is my experience from using the SMC M 5.6/400.
If you are shooting these older long telephotos wide open, you are going to get some softness and CA. They need to be shot on a tripod and stopped down to f8-11 in most cases.
The tokina 400 4.5 AT-X AF is a great lens for the money.
12-06-2014, 02:44 PM   #17
csa
csa's Avatar
QuoteOriginally posted by Outis Quote
I have actually lived very happily without a 50mm in my lineup! I just can't think of what I'd use that focal length for. The 50mm would generally be too narrow for landscapes, so it would end up being a portrait lens, but I already have the 77 for that. I wouldn't mind picking up an old one just to play around with it, but there's no particular hole it would fill for me.
A very good point! However, as another member pointed out; a fast one would be excellent for low light situations.
12-06-2014, 02:48 PM   #18
True, but I got very far with my 31mm f/1.8. Depending on what you like to take pictures of, you might do better with a fast normal lens (in the 30 to 40mm range).
12-06-2014, 05:09 PM   #19
QuoteOriginally posted by csa Quote
Uh, out of my price range!
A *300 will be in your price range someday, when you realize what it can do for you.
12-06-2014, 05:26 PM   #20
csa
csa's Avatar
QuoteOriginally posted by DSims Quote
Not if I plan on continuing eating, and having heat. A hobby can't replace these essentials.
12-06-2014, 05:29 PM   #21
I suppose this was in another discussion I missed, but if your body is anything since (and including) the K10D or K200D, you need a couple of lenses first.
For example, my K200D with the FA135 on it is the best IQ I can get with about $600 worth of equipment (I know what you're thinking ... how about the iPhone? ).
I consider the DFA 100 WR macro the best overall macro you can get, and I have one. But unless you're really into macro, save your money and get one of the many different-branded variants (AF or MF) of the Cosina 100/3.5 macro.
After all, if you can afford a $500 body and $600 lens, you can afford a $1000 lens, or two or three lenses worth about $1000-1200 combined. I didn't upgrade my K-x until I'd spent at least 5-7 times the price of the body on lenses (and I bought the body when it was newly released for around $650). When I finally upgraded to a K-5 it was anti-climatic, because it hardly improved my IQ (all the IQ improvements were already coming from the lenses when on the K-x).
12-06-2014, 05:32 PM   #22
FantasticMrFox's Avatar
When I decide to turn loose of the zooms; then I would consider some prime lenses. For now, I simply cannot afford to completely revamp & fill my lineup with top lenses. I guess I should have titled this thread as "near future" lineup.
Well, then add as affordable, but really good primes:
DA 50 f/1.8
DA 35 f/2.4
12-06-2014, 05:37 PM   #23
csa
csa's Avatar
Yes, I only have the K10D presently.
Update!! My spending is done for several months now, as I just committed to buying a Tokina 400mm!!! I'm a happy camper! I think my next lens will be the DFA WR 100 Macro, as I do a lot of macro shooting.
The new body will now wait.
12-06-2014, 06:24 PM   #24
That was a good move (spending it on the lens)! Congrats. Enjoy your lens! Don't sell your K10D as long as it's working OK for you, even if you upgrade. I still use my K200D occasionally, just to get the nice output from its 10MP CCD sensor.
The DFA 100 WR macro should give wonderful results on your K10D. It's just an excellent lens. And as I'm sure you already know, unlike many other ~100mm macros, it also does very well at normal, non-macro focal lengths.
12-06-2014, 06:31 PM   #25
Under most circumstances I'd advise to get a better lens over a better body, but realising that you're shooting a K10D (released 8 years ago!) you might actually want to consider an upgrade. Currently the K5 II(s) is pretty much shelled out at ridiculously low prices and I'd go as far as to say that the advances in camera technology over the last 8 years (resolution, high-ISO, dynamic range, metering, autofocus etc.) easily rival the advantage you'd get from a new lens.
12-06-2014, 06:55 PM   #26
csa
csa's Avatar
Thank you, I'm pretty excited! No, I would not sell the K10D; I really love this camera; perhaps that's why the lens came before another body!
That's good to know about the 100 macro, also. That definitely will be my next lens!
12-06-2014, 06:58 PM   #27
csa
csa's Avatar
QuoteOriginally posted by FantasticMrFox Quote
I'm enjoying the K10D, and it will serve me very well until I can get an updated body. A lens like this Tokina in mint condition doesn't come around that often, so I feel very lucky to have the opportunity to get it.
12-06-2014, 08:50 PM   #28
dadipentak's Avatar
Also I hear that one cannot live without a 50mm in their lineup; so suggestions as to which one!
One absolutely can--it's the most boring FL ever!
Also, forget those 400mm lenses--get the DA*300/4. Don't worry about 'overlap' with the 55-300: the zoom is about the zoom--not about 300mm . Those 400's are ok but they can't touch the DA*300 (with or without a good TC)
That's what I say.
12-06-2014, 09:54 PM   #29
csa
csa's Avatar
QuoteOriginally posted by dadipentak Quote
That's what I say.
I've already made a deal I can afford, on a 400!
12-06-2014, 10:33 PM   #30
Des
Des's Avatar
I'm content with my current 55-300, but hadn't thought of a good 300mm, what's available? Keep in mind I cannot afford a $1,000+ lens!
FA*300 f4.5 - around $800 or so. (The F*300 is a little lighter, but more expensive - hard to find for less than $1000.)
Sigma 300mm f4 APO AF tele macro - about $400-500 (but rare as hen's teeth)
body, fa28, future, k-mount, k10d, lens, lenses, lineup, pentax, pentax lens, slr lens, suggestions, tokina
Thinking about cleaning out some of my lineup. VoiceOfReason Pentax SLR Lens Discussion 21 06-25-2014 02:03 PM
Ricoh Imaging Enhances K-Mount Lens Lineup with Debut of Rear Converter Autofocus Fun Adam Homepage & Official Pentax News 5 02-06-2014 09:22 PM
Ricoh patent: 28mm equiv. lenses - Future of GRD and GXR? JPT Pentax News and Rumors 2 07-07-2012 08:04 PM
The Future of Sigma and Tamron Lenses for Pentax Sol Invictus Pentax SLR Lens Discussion 18 04-19-2012 02:24 PM
The future of lenses? YJD Pentax SLR Lens Discussion 6 09-04-2008 02:26 PM
All times are GMT -7. The time now is 09:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
