Quote: but the 2.0 focus ring turns from stop to stop but dosen't focus(no lens movement either). There is slight resistance about halfway between stop.. can this be easily fixed or should I just use it for display??
I've had a similar issue with an A50/2.0. The focus ring is clamped to the helicoid mechanism that moves the optics involved in focussing by 3 screws. This allows the lens to be calibrated so that the distance scale is accurate.
It sounds like your focus ring is loose. It might just have come lose, but it might also be because there's a problem with the lens. In the case of mine, it had been dropped at some point and bent the focussing mechanism. There was no obvious physical damage (presumably it had a lens cap/hood on), but the focus mechanism was jammed solid.
In any case, as others have said, the 50/1.4 is a much better lens, so you have nothing to lose by trying to fix it if you're interested. There are instructions on how to strip down an M50/2 here at the link below. Mechanically it's very similar to the A50/2. Have fun...
Pentax 50mm repair 1
