Originally posted by Wingincamera I want to get a DA21, is there a way to check the screws & locktite seals? Maybe reapply the locktite?
See this post for pictures:
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/121842-prob...ml#post1262737
1) Remove the hood.
2) Remove the center "beauty ring" - note that it does not include the plate with the name, specs, and serial number. It is actually held in place with double-side tape. Using a very small flat screwdriver, pry up around the edges of the optic (it can be done without touching the glass, just be careful). There is a second beauty ring with the name, etc., but it can be left where it is.
3) This will expose three cross-point screws. Remove these screws, and the front ring that the hood attaches to will come off.
4) This will expose the three problem screws. They are around the outer edge of the lens - it should not be necessary to touch any of the other screws. Check that the three outer screws are tight (but not too tight, or the lens won't be able to focus). Apply locktite.
5) Reverse steps 3-1.
If you have a lens that has come apart, the most important thing is do
NOT bump or squash the brass AF contact "comb". It is frightfully easy to bend or break, and then the lens won't autofocus. If you bend a contact, Don't Panic! It should be possible to straighten it by squeezing gently between your fingers. Just go slow and be gentle. Getting the front half of the lens reinserted in the back half can be a little tricky because of the comb. Rather than inserting it straight in, you have to hook the piece with the comb into the back half of the lens, then jiggle the rest in place. I got most of the way there, then had to hold everything together in my left hand so that I could get at the rear of the lens and line up the aperture linkages with a small screwdriver.
