Originally posted by K-Three I've had the Pentax 18-250mm on my K200D and K5, was my "carry everywhere" kit for a long time,
When I bought a K3 it came with the 18-135mm, it's a noticeably sharper lens, coupled with the greater sensor resolution. The reduced noise and speed of focusing of this lens is nice too
I did miss the extra reach, which you can almost get with cropping from the K3, similar quality for 250mm on the K5
So I did as Docrwm is, and picked up the 55-300HD WR,
Now I have a weather sealed kit to haul everywhere, with reach from 18-300mm.
Still have the 18-250mm, my wife uses it mostly now,
I do miss the convenience of one lens, but so far the results seem worth the extra weight and hassle of a lens change.
Don't miss the zoom creep of the 18-250mm, it has now gotten so loose that it's not creep anymore, it falls down as soon as you undo the lock. Should invest in one of the elastic band solutions.
I too live in a wet climate, and have not had any trouble with my non-WR gear, but now have a greater peace of mind taking my gear with me regardless of the forecast.
I usually pack the DA35-Macro for a fast normal too, It all packs into a small LowePro shoulder bag, that is not too conspicuous.
I've got other kit I haul when I'm specifically going out to shoot, but this is what I carry around daily for the opportunities that crop up when you are just running through your life.
It looks like we handle EDC with the same philosophy
I solved the falling with a sylicone band, I guess they all end that way, with no friction at all.
