I got FA31mm recently. I had some simple sharpness tests. While the center sharpness definitely is very good comparing to my other prime lens, I found the left bottom corner is kind of soft. The lens itself does not suffer from wobble issue.
Here is the shot F1.8, 1/1000 with tripod, wireless mirror lock up, Live view focused at center. I used the electronic level in camera body together with the bulleye on my ballhead to help locate the equal distance. The scaling factor is 1.27 to get lp/mm value here.
Crop: LeftBottomCorner F1.8
Crop: RightUpperCorner F1.8
The left bottom corner is soft as I noticed comparing to other corners, especially comparing to the right upper corner at wide open: And with the aperture decreasing, it improves and begin to match up a little bit.
And this is F8 1/60 F1.8
Crop: LeftBottomCorner F8
Crop: RightUpperCorner F8
I did the same tests on my DA 50 1.8 & Tokina 90 2.5 & DA 18-135mm . At wide open, FA 31mm sounds to be much soft comparing to Tokina 90 2.5 and even a leg behind DA 50 1.8 at corner. Surprisingly it ties to DA18-135mm at wide openat this focal length. I indeed tried to focus in different place and focus only on corner under live view 10x but every time I focus, the left bottom corner is still notable soft than other places despite that I focused on the left bottom corner. The left bottom corner cannot achieve the same resolution or apparently far below the readings from other corners.
If quantifying those numbers, at wide open,
Worst corner Averagecorner center
Fa31f1.8 40 59 78
Da50f1.8 60 65 75
Da18-135f4@30mm 50 55 80
Should I return this lens? Still several weeks to go. Did someone experience the similar issue when buying new fa31?
