Originally posted by Nicolas06 A further assessment is still more troubling. It seems that many camera makers are raising the ISO sensitivity when the lens opening is at its widest, probably to cover up the lack of efficiency. “We have ascertained,” explained Guichard, “that on many cameras, the ISO is pushed up on the order of 1/3 to 1/2 stop when the lens opening comes close to its upper limit."
Originally posted by Nicolas06 The isos are bumped without saying or registering in exif to show a beautifull 1EV difference between f/2 and f/1.4.
From what I have seen Pentax cameras
do not do this - for example the SMP-K 50mm f/1.2 ( which is a fully manual lens and therefore the camera body has absolutely no Idea of what aperture is being used) correct exposure is able to be obtained and verified with an external meter at f/1.2, therefore the lens is transmitting the correct amount of light - and the sensor is not boosting anything. If you take an image with the FA77 at f/1.8 at the "A" setting and set the aperture ring to f/1.8 and take another image, there will be
no difference in exposure between the two images
. On a Canon DSLR, using a manual Takumar 50mm f/1.4 and switching to a EF 50mm f/1.4 - both lenses when used at f/1.4 will give
different exposures for an identical subject - that is because the Canon DSLR is fudging the ISOs - that trick only works when the camera body can communicate with the lens.
Originally posted by Nicolas06 It apply to all camera manufacturer and is not pretty
Some manufacturers are worse than others, Fuji with their X -trans sensors falsified ISO ratings spring to mind.
Originally posted by Nicolas06 Digital sensor don't fully leverage f/1.4 or f/1.2, even more so APSC sensors due to the angle of incidences of the light rays
Again, this is based on incorrect assumptions - the APS-C sensor is making the best use of the lenses image circle by only using the center "sweet spot" of the lens where the acute incident rays are less likely to be a problem. On FX format acute incident rays are much more problematic due to the increased image circle requirements.
Pentax K5IIs-SMCP-K 50mm f/1.2 @ f/1.2
