Originally posted by cbope Sorry, I don't get the comparison of variable aperture long range zooms to much shorter range fixed aperture zooms. Different classes of lenses, imho...
Although it's absolutely true that these are different classes of lenses, and that many photographers, particularly those that absolutely need f2.8 in their zoom, will not care how the slower zooms perform. However, if you're a landscape photographer looking for the lens that performs the best at f8 regardless of weight, size, zoom range or aperture, then a comparison involving all zooms would be of much interest. At one point, I seriously considered getting the DA* 16-50, even though I would rarely, if ever, have used the f2.8, for the simple reason that it seemed the very best standard APS-C zoom lens for the K-mount. In the end, reports of decentered copies along with all the horrors of the assorted SDM woes, persuaded me to go in a different direction.
Originally posted by cbope The DA 16-85 would have to be mind-blowing for me to even consider replacing my DA* 16-50 with it, and I don't believe that's going to be the case.
Except for those whose minds are easily blown, I doubt anyone's going to find the DA 16-85 mind-blowing. Nonetheless, I think it will likely prove a very good lens, with performance coming close, though not quite equaling, the DA* 16-50 (at comparable apertures/focal lengths).
As to the original question of the thread, the DA 20-40 vs the DA 16-85, if I had deep enough pockets, I'd get them both, as they both have uses, depending on the situation (I would not, to be sure, ever carry both of them with me at the same time). But if I could only get one, I'd get the DA 20-40, as the shorter lens involves fewer compromises.
