Originally posted by NicoleC The K-x is dead. The K-3 was my replacement -- otherwise I'd agree that new glass would have been the priority over a new body.
Oh, sorry. I didn't realize you don't have the K-x anymore.
Originally posted by NicoleC I don't know exactly, but that's a good question. I do know I could only handle the Sigma 70mm (527g) on the K3 for about 2 hours pain-wise, and it went over a cliff an into a river largely because I just couldn't grip it strongly enough to safely change lenses at that point. The DFA 100 (345g) hasn't been a problem at all.
With the Pentax DA 16-85mm clocking in at 488g, and the Sigma 17-70mm at 465g, perhaps I should remove it them from consideration and just think about primes.
I light of this, I can't help but wonder if a non-Pentax (or at least non-DSLR) solution would be better. I'm thinking of the weight of the body, mostly. However, since Pentax has good ergonomics, perhaps that compensates for/balances the weight? BTW, do you use a battery grip? Have you tried one, and does it help? The first time I ever shot a cross country running meet, I gladly paid the price of a battery grip the next day. I took 1000-1500 photos in about two hours (no easy "machine gun" shooting either), and over 90% of them were in portrait mode. My arms simply got too tired. With the "vertical" battery grip my next meet was much easier. Some people prefer the grip for horizontal shooting as well.
If you're staying with the K-3, the FA (or F) 135/2.8 and DA70 come to mind as good choices. On the wider end I believe you'd like the DA35/2.4 or FA28.
But I have a hunch the DA70 and DA21 would be just perfect for you. You can sell or return the DA15 if you need to - don't worry, you can always find another one, and it sounds like you may have a poorer copy anyway (which is unusual, I believe). For me it's the FA*85 and FA*24 I use so much, but the DA70 and DA21 are very close in focal length - plus they're also more "precision" in their rendering than even my * lenses, I think. And you can't get any smaller or lighter than those two! I find I rarely use focal lengths around 50mm, but if you're worried about the "gap," then the DA35/2.4 is an inexpensive add-on. I like it better than the DA35 macro anyway - it's faster, it's very good wide-open, and it's much more affordable.
I've really put some thought into this - it's hard for me to imagine a better combo (based on your descriptions and needs) than the DA70 and DA21, plus a DA35/2.4. Other than the DA35/2.4 (which I got for my daughter) they aren't quite my style, but I think they're yours. And if you're
really worried about gaps, the FA28 is reasonably priced, and the DA50/1.8 is extremely affordable as well. It wouldn't have to be a big hardship to get any (or all 3!) of these later. How can you lose? Every single one of these 5 lenses easily meets your criteria, IMO. Each of the more affordable ones has very nice IQ, and they're bookended by two very-high-quality mid-range lenses which I think you'll be using the most.
You don't like your DA15, so you need to get rid of it, and perhaps give it another chance some other day. Replace it with the DA21. It's not like DA15s are hard to come by - like I said, you can always get another. That's why I sold mine - I really liked it, but I had higher video-based priorities that came up, and DA15s are readily available.
Just in case you haven't seen these -
DA70:
PENTAX : Select a PENTAX interchangeable lens camera or a lens model PENTAX : Select a PENTAX interchangeable lens camera or a lens model PENTAX : Select a PENTAX interchangeable lens camera or a lens model
DA21:
DA35/2.4:
DA50/1.8:
FA28:
FA and F135:
Of course you do know you could improve your IQ by simply getting an F24-50/4 and an F70-210/4-5.6, don't you? The F24-50/4 is a bit harder to come by (although I found one), but the F70-210/4-5.6 is readily available under both the Pentax and Takumar brands.
