Originally posted by alegznn which I would like to adapt for use with Canon EF mount
alegznn, I use numerous Pentax K lenses on multiple Canon and Pentax bodies, and I often carry both brand bodies and interchange the Pentax lenses between the systems. Before you even think about modifying the lens, please first confirm the model Canon you want to use this with. Most of the APS-C Canon bodies do not require any lens modification. The mirror is smaller on the these, and it clears the lever. If you want to use it on a Full-Frame sensor body (6D, 5D, 1D...) you only need to modify the lens if you want to use the optical view finder. You can even use an unmodified Pentax lens on the Canon Full-frame body if you activate live-view mode
before attaching the lens, and then detach the lens before deactivating live view. If you are shooting on an older Canon film body, you must modify the lens.
