http://c758710.r10.cf2.rackcdn.com/files/support/manual/1394730000_DA_Rear_c...lity_Chart.pdf
Some FA lenses are listed. It looks like the ones still available are listed. Plus they show some that should not be used.
Missing from the chart however are the ones most likely to be used such as the FA*300 or FA*400. I think you can look at the rear element of a lens while running through the full focus or zoom movement and see if the rear element comes close to the mount. If it does then I would be concerned, if not then there should be no conflict.
