Just to take up a point raised by @frogoutofwater and @emalvick, I have both a superzoom (Tamron 18-250) and the Pentax 55-300. I can add something about the comparison.
No question that overall the 55-300 produces better images. It is about a stop faster across the range (at 200mm it is f4.5, and 250mm is f5.6, which is not bad for a lightweight zoom). Also, because it is not an internal focus lens, it has greater magnification at any given focal length than the 18-250 (other than when focused to infinity). So the advantage in reach is much greater than 250mm v 300mm: what the Tamron can reach at 250mm, the 55-300 could often reach at 200mm. For wildlife that is a big advantage.
But there is more to the comparison than this. If you framed the subject in the same way (which - just guessing - might mean the 18-250 at 200mm and the 55-300 at say 150mm for a subject 6 metres or 20 feet away), and stopped each down to say f8, you would need to be a dedicated pixel peeper to tell any difference in resolution. After correcting in PP, I would have to look at the EXIF info to see which lens it was.
If you are a dedicated pixel peeper, have a look in these reviews and you will see that there is not much in it for centre sharpness stopped down:
Tamron AF 18-250mm f/3.5-6.3 Di II LD Aspherical [IF] macro (Canon) - Review / Test Report Pentax SMC DA 55-300mm f/4-5.8 ED - Review / Test Report
At the wide end, particularly wider than say 70mm, I would actually prefer the Tamron even though it is a little slower (f4.5 v f4 at 55mm, and f5 v f4 from 70mm-100mm) - I think the colours are better, and I prefer the bokeh (although neither is great for this). The variation in individual copies might account for more of the difference than inherent design. Maximum magnification is similar (about 1:3.5) but the Tamron's minimum focusing distance (450mm v 1400mm) makes it much more usable. If you don't have the WR version of the 55-300, it doesn't have any advantage in robustness; like Earl, I have found the 18-250 very robust. The 55-300 is about the same weight but physically a bit longer - it won't quite fit on the camera in my snout bag.
I have never used the 18-135, so I can't compare it to the 18-250. But there are plenty of user reviews and comparisons out there and the consensus seems to be that the 18-135 is a bit better.
My view is that,
as a two-lens solution, the combination that frogoutofwater suggests (18-135 + 55-300, especially with the WR version) makes a lot of sense. The overlap in focal lengths is an advantage, and their strengths are complementary (the 18-135 at its wider end and the 55-300 at its longer end). But the question was, is a
one-lens travel kit worthwhile? To which I would say yes - get the 18-135 if you don't need the extra reach (for wildlife etc) and a good superzoom if you do. Of course there are compromises, but particularly for outdoor use what is lost in IQ is more than compensated for by the gain in versatility.
