You already got some good advice. Let me add a few comments.
You need to consider your full lens road-map. You already have the DA40mm and this will influence my suggestions, assuming that you will keep the DA40mm. I see three options:
DA*55mm 1.4 and FA85mm 1.4
FA43mm 1.9 limited and FA77mm 1.8 limited
FA31mm 1.8 limited and FA77mm 1.8 limited
Pros: complement nicely your 40 mm - excellent lenses with outstanding IQ
Cons: no wide angle lens in the line up - bulk of DA*55mm (and to some extent FA*85mm) - FA*85mm available 2nd hand only and expensive
Pros: excellent lenses with outstanding IQ - small compact lenses
Cons: no wide angle lens in the line up - overlap between DA40mm Ltd and FA43mm ltd
Pros: excellent lenses with outstanding IQ - small compact lenses- complement nicely your 40 mm -
Cons: not much in my opinion
To sum up, you are considering excellent lenses and you cannot be disappointed by their IQ. But the FA43mm selection is no consistent and would overlap with your DA40mm Ltd (a great lens in its own rights). I think that the selection of FA31mm/FA77mm makes more sense because it gives your a better breadth of focal range.
But, why do you seek some large aperture lens? Do you want to shoot in low light or simply after shallow DOF? For low light and very low light, you may consider other lenses, incl. MF lenses. The Voigtlander lens series and Carl Zeiss lens series offer some incredible option, if you are willing to go MF.
I hope that the comment may help.
